Mike's new wheels from OE
I don't have power steering either. I hope my 215 60 15 tires are not too hard to turn. I think they will be fine.
It probably turns great with 205s.
I don't plan on ever putting power steering on mine. I have had some friends and known a few others that had nothing but problems with power steering. It was either leaks or the pump going out etc.
The back spacing on those is 6.80 and some change...
I'm running a 71 rear on my car so I've gained an inch on each sides...
Those 10.5 on a 69 specs, might be rubbing on your leaf spring depending on the tire you choose.
I'll have tires mounted tomorrow (315/35-17) and I'll take picture for you and see if that rim is a bit over an inch away from the springs.
If so, you'll be OK.
Remember, it's going on a 70 Cougar and I was already running the 98 Cobra style (FRPP #D-178) when they came out.
I loved the style but they were not wide enough to be somewhat flush with the bodywork, even with a 1 inch spacer!
Until OE came up with the 10.5
and I came up with a wider rear end too.
My car got wacked 2 years ago and I lost interest, was too disgusted...
I instead built my 06 and worked on my 68 fastback project.
Now I'm pumped again about finishing up the old cat...
and I came up with a wider rear end too.My car got wacked 2 years ago and I lost interest, was too disgusted...
