tiger striping
Old Feb 8, 2009 | 06:41 AM
mortman's Avatar
mortman
Default tiger striping
Ok, i have read what my mistake was when painting, question is how to fix tiger striping before clear? Color is Ford Royal blue.
Old Feb 8, 2009 | 07:36 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
how does your spray pattern look when spraying against the wall?
i dont know what paint your using but most have a time window for clear you may need to wetsand with say 2000 grit before re-basing and clearing.you will need to check your tech sheet
spray pattern problems
Old Feb 8, 2009 | 08:08 AM
mortman's Avatar
mortman
Pattern looks good but obviously its not, i fogged over the hood and it looks like it cleaned things up but theirs dark and light spots now. am i just chasing my tail? i am using ppg deltron 2000 dbc, clearing with ppg concept 2042
Old Feb 8, 2009 | 11:38 AM
Starfury's Avatar
Starfury
I agree with rmodel, you probably need to sand and respray the base.
How many passes are you making? Two passes often isn't enough with a metallic.
Old Feb 9, 2009 | 11:11 AM
chris66dad's Avatar
chris66dad
You will need to sand and shoot a new base coat. What you see now will be there forever if you clear coat.
I believe the stripes are coming from when you change your pass direction (left to right then right to left). You are probably not holding the gun at a 90 degree angle to the surface with each pass. Laying down the metallic paint at different angles can make stripes
Adjust the pattern, hold the gun at the same angle for both directions and allow 50% overlap.
Setting up the gun is very important to avoid orange peel (too much fluid) or runs (not enough air pressure or speed). good link: http://www.southernpolyurethanes.com...your%20gun.htm
Make sure you stay within your time windows from the tech sheets. I like to write down the time I start /finish for every coat so there is no chance of getting the times wrong.
Good luck and stay with it!
Suree_Mustang_2009
Sep 25, 2015 12:58 PM
Mr. D
Sep 16, 2015 11:04 PM
unit91
Sep 15, 2015 09:53 AM
mustangv6305
Aug 29, 2015 01:37 PM
Mr. D
Big Worm Graphix
Aug 18, 2015 01:51 AM
