Electronic Ignition Conversions
Old Feb 10, 2009 | 04:14 PM
gcstang65's Avatar
gcstang65
Default Electronic Ignition Conversions
Hello,
I'm looking at changing the distributor or points on my '65 has anyone used an EI conversion from Crane Cams. This will go right into the same distributor without having to change the whole unit. I can included a picture for reference if needed...does this work? How is the performance?
Old Feb 10, 2009 | 06:14 PM
groho's Avatar
groho
If it's anything like the pertronix unit, it's a piece of cake to put in and set. Be sure the check instructions for the input voltage for the pick-up. If you intend to change the coil also, make sure to check the min input voltage needed there also. Stock 65-66 is about 9V, but some of these systems require 12V, so you may need to by-pass the resister wire under the dash. I believe it's the pink wire out of the back of the ignition switch. Add a T-connect at the bullet connector, and you have 12V going into the resistor wire, and 9V after the resistor wire, so you can use either as a source.
Old Feb 10, 2009 | 07:57 PM
JHPSTANG's Avatar
JHPSTANG
A guy I was talking to the other night said something about the petronix causing arcing with the voltage regulator (or something like that). I didn't get all the details. Anyone heard of this?
Old Feb 10, 2009 | 08:13 PM
1slow67's Avatar
1slow67
ROTM Moderator
Nope. I've had pertronix for over a year.
Old Feb 10, 2009 | 11:08 PM
tx65coupe's Avatar
tx65coupe
I don't personally have one, but a friend of mine and his dad have the pertronix in thier cars and have had them for years with out any problems.
Old Feb 10, 2009 | 11:46 PM
jonward786's Avatar
jonward786
if you do end up going with a pertronix, learn from my mistake and dont use a flamethrower 2 coil with an Ignitor 1 module, you will burn it up in 20 minutes of idling
Old Feb 11, 2009 | 12:51 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
how about this, you will be able to get replacement parts from any parts house
http://www.mustangsteve.com/conversion.html
mrtrodonet
Sep 19, 2020 03:12 PM
bradleyb
Nov 27, 2015 07:50 PM
piotrek53
Oct 13, 2015 06:54 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Wombatnation
Sep 13, 2015 09:16 PM
