Removing Front Seat
Old Feb 11, 2009 | 10:47 AM
Swedish_GTFastback's Avatar
Swedish_GTFastback
Default Removing Front Seat
Hi
I am about to take out the drivers seat, I live in Sweden and we have Metric so what size is the nut under the car ? As i need to try to buy a tool to unscew this nut ! Its for a 1966 GT Fastback
Thanks
Old Feb 11, 2009 | 10:56 AM
fakesnakes's Avatar
fakesnakes
I believe those are 5/16 studs and use a 1/2" nut. A 13mm socket should do the trick. I would use a rachet and extension to get to the bolts as they are recessed. There should be rubber plugs you have to remove to access the nuts, but they may have been removed by a previous owner.
Old Feb 11, 2009 | 11:20 AM
rst08tierney's Avatar
rst08tierney
Be care full not to drop the nut inside the floor pan
Old Feb 11, 2009 | 12:03 PM
Swedish_GTFastback
Thanks very much for the quick replies.
Seat is out and going to be reholstered
Old Feb 11, 2009 | 07:00 PM
'68 Convert.'s Avatar
'68 Convert.
Use a six point socket if you have one, it will grip the 1/2" nut a little better.
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
Oak
Sep 14, 2015 03:08 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
v8sn95
Sep 7, 2015 10:17 AM
