17x8 or 17x7 fronts?
Old Feb 16, 2009 | 06:49 PM
dodgestang's Avatar
dodgestang
Originally Posted by true66gt
S HIT!
god fking damnit. i was positive the 4.75" tt2s wouldve worked perfect with the wilwoods. FU CK. EVER ****ING TIME. i cant win with tire/wheel/brake combos. damnit so now what do i do? what if i put a 225 tire on a 7" rim? then what backspacing will i need? i dont want it to look like that picture. what do you have on yours dodgestang? thats what i want. can i make mine look like your and use my wilwoods? cause im sure as hell not returning my brakes.
On my car I run 17x8 4.75 in the front with a 245 40 17 tire with the stock style kelsey hayes brakes with shelby dropped control arms, 620 drop springs, roller perches, and adjustable control arms. I run 1/8 toe, +3 caster and -2.5 camber and do not have the fender rolled.
If you get exact measurements on the track width change between stock and wilwood brakes it should be easy enough to replicate but it would probably require custom wheels which is an expense you might not want.
I believe there are some late model wheels that are 17x8 with 5.5 backspacing, you could use those and then a small spacer to make up the difference...but then you would have to mess with adapters in the rear as well.
I'm sorry, I hadn't realized the photo I posted was 16s....16s have a little harder to fit on the ball joint 17s let you run .25 more backspacing (4.75 instead of 4.5 on an 8 inch rim).
Old Feb 16, 2009 | 11:32 PM
ky's Avatar
ky
America ftw
you gotta be ****ing kidding me.
god dammit now i might as well give the ****ing car away. my whole dream was to have wilwoods and tt2s. and i checked and double checked and everyone said it would work. now theres basically no point in me finishing the car. the wheels are the most important part. and im NOT going with ANOTHER wheel.
Old Feb 16, 2009 | 11:53 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
dude get some polished bullits and deep dish bullits in the rear
Old Feb 16, 2009 | 11:54 PM
MonsterBilly's Avatar
MonsterBilly
You can have TTII's made in whatever offset you wish. Especially if you go polished aluminum. They run about $400 each. You would only have to have the fronts custom done. Therefore, a standard wheel size and offset will fit the back. You only have to have 2 of them custom made. you will only be spending about $400 extra.
Not a big deal if you ask me.
Discount Tire Baby!
Old Feb 17, 2009 | 12:08 AM
ky's Avatar
ky
America ftw
TT2s are $230 each at summit racing.
Old Feb 17, 2009 | 12:10 AM
ky's Avatar
ky
America ftw
dodgestang would the 17x8 wheel fit with a 5" backspacing? and would the wheel look funky?
Old Feb 17, 2009 | 12:12 AM
ky's Avatar
ky
America ftw
my main concern is i want lip on the wheel. i want deep lip. otherwise i wouldve stuck with the 05 bullits i had.
Old Feb 17, 2009 | 12:22 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
shallow lip front, deep lip rear=win
Old Feb 17, 2009 | 12:30 AM
ky's Avatar
ky
America ftw
deep dishes dont come in a 17x8 or 9 wheel. and a 10.5 wheel wont fit.
Old Feb 17, 2009 | 01:23 AM
Hlistr_07RR's Avatar
Hlistr_07RR
I always jizz first
Listen to Rmodel, he knows his crap....
What are you doing out of OT, get back in there
