radio
Old Feb 17, 2009 | 06:42 PM
slick66stang's Avatar
slick66stang
Default radio
i finally got a original radio for my 66 coupe. i want to see if it works. all four wires are there. a black wire with a yellow cap connector a blue wire with red stripe and a red cap connector and two black wires one with a green stripe with a dual connector. can anyone tell me which is the power wire the light wire and the speaker wire? thanks
Old Feb 17, 2009 | 08:07 PM
92ponyranger's Avatar
92ponyranger
I need to know this also. I don't plan on making mine work, just need the light to work. I only paid $30.00 for mine.
Old Feb 18, 2009 | 08:56 AM
urban_cowboy's Avatar
urban_cowboy
Check out the wiring diagram section in the FAQ section. It is your friend!
http://midnightdsigns.com/james/FAQs.htm
This is the radio diagram for a 65.
http://www.hammar.dyndns.org/~djhamm...1965/1965i.jpg
This is the radio diagram for a 66.
http://www.hammar.dyndns.org/~djhamm...6/66acces1.jpg
This is the radio diagram for a 67.
http://www.hammar.dyndns.org/~djhamm...7/67radio1.jpg
This is the radio diagram for a 68, 69,& 70
http://www.hammar.dyndns.org/~djhamm...g/1968/E15.jpg
Old Feb 18, 2009 | 09:13 AM
92ponyranger
From what I can tell, the blue/red is power, black is ground, and the dual plug are speaker wires. I could be wrong and the single black may be power for the light..?
http://www.hammar.dyndns.org/~djhamm...6/66stereo.jpg
Old Feb 18, 2009 | 09:29 AM
zmetalmilitia's Avatar
zmetalmilitia
From what I can tell, the blue/red and black/red are your power leads. Orange is a L/R speaker, white is a L/R speaker, and the black is a common wire (ground). Is the unit installed and wired up? Do you have access to a multimeter? If so, check the wires to see what is providing what voltages.
Is this a new unit? Sounds like someone wired it up to make sense to them. Green wire is usually ground.
kevsgt
Oct 9, 2015 10:12 PM
breaking
Oct 2, 2015 01:27 PM
vbonina
Sep 22, 2015 08:31 AM
Gkid182
Sep 22, 2015 08:17 AM
unit91
Sep 15, 2015 09:53 AM
