Found a Craigslist rearend
Old Feb 19, 2009 | 01:04 PM
Stangman70's Avatar
Stangman70
Default Found a Craigslist rearend
Found a rearend on craiglist. Its out of a 78 lincoln mark V i think. Would it be a direct bolt in for my 70 coupe. Its a 9" with disc brakes, didn't say anything about the splines though.
Old Feb 19, 2009 | 02:14 PM
Mustangdemon67's Avatar
Mustangdemon67
you would have to check the length from axle flange to flange. then check if the rear housing already has spring perches mounted on, and if they are, check the gap between them and see if your leafs are the same. and check the yoke on the third member and makes sure its the one you need for your driveshaft. thats all i can think of
Old Feb 20, 2009 | 10:03 AM
htwheelz67's Avatar
htwheelz67
A lincoln mk v had a coil spring suspension so it would take some major mods to make work.
Old Feb 20, 2009 | 01:05 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
the lincoln is a boat, id imagine you will need to shorten the axles
Old Feb 20, 2009 | 02:25 PM
chris66dad's Avatar
chris66dad
Default $375
Has a picture on ad
http://sfbay.craigslist.org/sby/pts/1042950129.html
FORD 9" REAR END.. fits 67-70 MUSTANG - $375 (san jose north)
Date: 2009-02-20, 10:10AM PST
MUSTANG - COUGAR 1967-1970 9" REAR END
5lug
leaf spring style
non posi
great working cond
being removed from 69 mercury cougar 351 car
$375
408-420-6004
4cylinderplus2
Oct 9, 2020 07:45 PM
jerrytubes
Oct 23, 2015 12:11 PM
Dokilar
15
Oct 16, 2015 08:13 PM
KingRando
Oct 2, 2015 08:06 AM
Drastang
Sep 30, 2015 03:48 AM
