Motor Oil
Since I'm going with the Comp Cams retro-fit roller cam (CL35-421-8) can I use a Synthetic oil right from the get go? I know I still have to use the Comp Cams break-in additive. I was thinking of going with AMSOIL 5W-30 Motor Oil (ASL).
You don't need to run any break-in additive with a roller cam. Roller cams and lifters are hardened steel and aren't subject to wear like flat tappet setups.
But yes, you can run synthetic as long as you're just doing a cam swap, not breaking in a new engine.
jaiidutch
Sep 14, 2015 10:29 AM
