Mechanical Lifters
Old Mar 31, 2009 | 10:32 AM
JapanGT's Avatar
JapanGT
Default Mechanical Lifters
If mechanical lifters were removed and not necessarily replaced in the correct order,
would that necessitate re doing the break in procedure?
Jav
Old Mar 31, 2009 | 12:24 PM
Starfury's Avatar
Starfury
It would necessitate replacing all of the lifters. Do not run the engine like that. Each of the lifters break into each of the cam lobes individually. They absolutely cannot be swapped, or you risk destroying your cam and lifters and sending metal shavings through your engine.
Old Apr 1, 2009 | 08:06 AM
JapanGT's Avatar
JapanGT
Good. I was looking for justification for a new cam/lifters/rods. I read something similar
on another forum.
Appreciate your comments.
Jav
Old Apr 1, 2009 | 08:48 AM
blue66mustang's Avatar
blue66mustang
Human sacrifice, dogs and cats living together... mass hysteria!
Old Apr 1, 2009 | 12:05 PM
Starfury's Avatar
Starfury
on another forum.
Jav
That's certainly one way to look at it
Let us know what you end up doing, and if you need help with cam selection.
Old Apr 1, 2009 | 11:05 PM
JapanGT's Avatar
JapanGT
I am thinking to use the following;
CAMSHAFT
Crower Street Roller Performance Level 4 Camshafts
Camshaft, Mechanical Roller Tappet, Advertised Duration 280/ 288, Lift .580/ .582, Ford, Big Block FE, Each
LIFTERS
Crower Roller Lifters
Lifters, Mechanical Roller, Vertical Link Bar, Ford, Mercury, Set of 16
TIMING GEAR
COMP Cams Magnum Double Roller Timing Sets
Timing Chain and Gear Set, Magnum, Double Roller, Steel Sprockets, Ford, Big Block FE, Set
DISTRIBUTOR
ACCEL Street Billet Performance Electronic Breakerless Distributors
Distributor, Street Billet, Magnetic Pickup, Vacuum Advance, Ford, 332-428, FE, Each
DISTRIBUTOR GEAR
Mallory Bronze Distributor Gears
Distributor Gear, Aluminum, Bronze, Race, .467 in. Diameter Shaft, Ford, Big Block FE, Each
Summit® Block Protector Kits
Block Protector, Steel, Roller, Ford, Big Block FE, Kit
TO WORK OUT PUSHROD LENGHT
Trick Flow® Adjustable Pushrod Length Checkers
Pushrod Length Checker, Adjustable Range 8.35 in to 9.8 in, Cup Style, Each
If you see any issue with parts I am using please let me know. I am going on what information
I can find rather than personal knowledge.
Jav
Old Apr 1, 2009 | 11:09 PM
JapanGT's Avatar
JapanGT
I believe Congress is voting on that next year. This year it is, "let’s put America into debt
for the next 20 years and build a path to hyperinflation."
Jav
Old Apr 2, 2009 | 08:07 AM
my77stang's Avatar
my77stang
FE motors are sexy
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
wraith777
Sep 28, 2015 10:49 AM
MusicCity615
Sep 12, 2015 07:05 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
