gauges dont work....go figure
Old Apr 1, 2009 | 11:07 AM
knuckless's Avatar
knuckless
Default gauges dont work....go figure
ok so pretty much my only gauges that do work are the speedometer gauge and gas gauge. luckily the only two i really need. but even when the tank is full the gas gauge read 3/4 full. how do i fix the gas gauge and is there any trick to fixing the other gauges or finding out why they dont work? anything to check for?
Old Apr 1, 2009 | 11:43 AM
MIL1ION's Avatar
MIL1ION
Did you post this question elsewhere ?
I remember answering this exact question somewhere else.
Old Apr 1, 2009 | 11:56 AM
knuckless's Avatar
knuckless
no i dont think i did, but could you answer it again?
Old Apr 1, 2009 | 09:05 PM
knuckless's Avatar
knuckless
anybody got some ideas?
Old Apr 1, 2009 | 09:09 PM
JamesW's Avatar
JamesW
Have you taken the guage cluster out and looked at it? maybe the wires have come loose.
Maybe the CVU is not working properly. Maybe the ground is corroded.
Take the dash out and start looking for the obvious. Then shout back.
Old Apr 1, 2009 | 09:44 PM
MIL1ION's Avatar
MIL1ION
If the fuel gauge is fine then the ICVR is fine.
Your problem is between the gauges and SU.
with the key on Take the wire from the oiul/temp sending unit and ground it out to the frame.
The Gauge should pin to the full side
Then check for 5 volts pulsing power to the S/U's with a test light.
It should flash like this.
jwog666
Dec 27, 2021 08:09 PM
jerrytubes
Oct 23, 2015 12:11 PM
breaking
Oct 2, 2015 01:27 PM
BeatnikFink
Oct 1, 2015 08:00 PM
guitarman376
Sep 30, 2015 05:54 PM
