71 9 inch in a 68?
Old 04-07-2009, 01:37 PM
countryboy116
countryboy116's Avatar
Default 71 9 inch in a 68?
Hey yall theres a guy locally to me sellin a 9 inch from a 71 mustang, wll this fit in my 68? i think its a little wider if i remember correctly but i figure maybe with the right offest wheels it would work, what yall think?
countryboy116 is offline
Old 04-07-2009, 01:46 PM
knuckless
knuckless's Avatar
flange to flange they are both 54" so it should fit
knuckless is offline
Old 04-07-2009, 01:51 PM
countryboy116
thanks, hopefully the guy still has it then and go pick it up, thanks again!
Old 04-07-2009, 02:28 PM
REAVER117
REAVER117's Avatar
Actually a 9" rear end from a '71 will be 2" wider:
67-70 59.25"
71-73 61.25"
It should still fit but you may have some issues if you run very tall or wide tires.
REAVER117 is offline
Old 04-07-2009, 03:36 PM
countryboy116
guy sold it anyways
Old 04-07-2009, 03:57 PM
Starfury
Starfury's Avatar
Are you doing a v8 swap, or are you trying to upgrade from an 8"? You may consider a fox body 8.8" rear. You'll have to hack off the coil perches, get leaf perches welded on, and pick up some 5-lug axles and brakes, but they're plentiful and cheap, unlike 9" rears.
Starfury is offline
Old 04-07-2009, 07:13 PM
andrewmp6
andrewmp6's Avatar
Which rear end do you have now a 8 inch or the 7.5?If its a 8 inch i would keep it unless you gonna make over 350hp then you need a 9 inch or 8.8.
andrewmp6 is offline
Old 04-07-2009, 08:21 PM
countryboy116
im upgrading from a 6cyl so my current rear end is the 7.5, i actually found a deal today guys parting out a foxbody, imma get the 5.0 with harness and computer plus a carbed intake on the side incase i wanna run carbed which i probably will for now, good cond t5, and a 8.8 rear end rebuilt with 3.55 gears which will be perfect for what i want to do, all for 1100 imma try and talk him down a little but it seems like a decent deal to me, all i have to do is convert the rear to 5 lug and weld the spring perches on in the right place right to run the 8.8?
EDIT: just rear your post starfury, thanks for that info, sounds like thats gunna be the best thing for me to do for now atleast
Thunderball
15
11-22-2015 11:49 PM
jrrhd73must
10-02-2015 09:17 PM
mungodrums
09-28-2015 10:54 PM
mungodrums
09-28-2015 05:45 AM
Quick Reply: 71 9 inch in a 68?
