Options?
Old Apr 15, 2009 | 02:14 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Originally Posted by Joe67
Self etching primer consists of phosphoric acid and zinc, so that will kill 2 birds.
personally i wouldnt use etch primer. i would use acid to etch then use epoxy primer afterwards better base imho.
Old Apr 15, 2009 | 08:55 AM
SJs 66coupe's Avatar
SJs 66coupe
Originally Posted by Green69
I painted mine with an Eastwood spray can a couple years ago and it is holding up fine so far. While you are in there, are you going to weld up all the unneeded holes? Post before/after photos, of course.
I was thinking of using something along those lines paint wise.
Already took the "before" pictures a few weeks back. Just waiting to get started on this till I can take a couple of days off and saving the rest of the money I'll need for the motor in the mean time.
Also need to find either a friend that will let me borrow a mig or more likely I will probably just buy one if I can find a good used one for sale local. I've been watching Craigs list and asking around on the grape vine.
Honestly, I don't see much reason why I couldn't go ahead and fix the fender apron now and then paint the apron to match when I paint the rest of the bay once the engine is out.
Old Apr 15, 2009 | 09:14 AM
Green69's Avatar
Green69
I used a rattle can because I didn't want to pull the engine. If you are going to replace the engine, why not wait until then to weld and paint. It would be soooo much easier with room to work. Someone had sprayed undercoating in the engine bay of my car, which was such a pain to remove.. I wish I had the engine out.
jwog666
Dec 27, 2021 08:09 PM
ChampInSD
Oct 2, 2015 04:55 AM
Mr. D
Oct 1, 2015 01:03 PM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
