hub removal
Old Apr 18, 2009 | 12:21 PM
Tony R's Avatar
Tony R
Default hub removal
any good recommendations for removing the hub from the drum.
Old Apr 18, 2009 | 12:31 PM
JERM_1967stang's Avatar
JERM_1967stang
BFH. should do the trick. i would assume your going to replace the 40+ yr old lugs any ways so hit it from the front and it should pop out the back. make sure your BFH is rubber or composite and not iron or steel. if it is iron or steel. use a wood seperator. and plenty of WD40
Old Apr 18, 2009 | 12:32 PM
RagHead's Avatar
RagHead
Place a piece of 2 x 4 across the hub and rap with a large hammer. Should drop out after a couple of blows. Mine did anyway.
Old Apr 18, 2009 | 12:44 PM
Tony R's Avatar
Tony R
that is what I was trying. I upgraded in hammer size and got it out. Thanks.
Tivo304
Aug 28, 2023 12:19 PM
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
