Did it again...
Old Apr 19, 2009 | 06:35 PM
Joe67's Avatar
Joe67
Banned
damn hold on
Old Apr 19, 2009 | 06:41 PM
Joe67's Avatar
Joe67
Banned
Old Apr 19, 2009 | 06:54 PM
Starfury's Avatar
Starfury
That's interesting. Only thing I could come up with for that is the vacuum modulator for the tranny. No idea where the other end went?
Old Apr 19, 2009 | 07:04 PM
Joe67's Avatar
Joe67
Banned
the one on the next to left goes into the one on the left, and was about 8" long with a tapered end. I had three people helping me when i pulled the motor, whom i no longer associate with... which really put me in a bad spot
Old Apr 19, 2009 | 08:51 PM
Joe67's Avatar
Joe67
Banned
also whats that peice on the far right
that may or may not have even come off the intake but instead the carb...
maybe choke? the rest of the piping was wrapepd in a white thermal sleeve.
Old Apr 20, 2009 | 05:04 AM
kalli's Avatar
kalli
Originally Posted by Starfury
The proper part will help prevent sucking air through the heater core, and is necked down at the elbow to keep from blowing out the heater core during high-rpm operation.
would you have a part # or where to buy? i'm using a standard 3/8 NPT straight, which is not the best of all options I guess
I can't recall if the threads on the Performer 289 are bigger than stock or not.
it's the same thread as stock 1966 289 V8. NPD part number: 10884-2
i believe that to be 3/8NPT as well
Old Apr 20, 2009 | 05:37 AM
fakesnakes's Avatar
fakesnakes
Perhaps the best way to approach this is to take a picture of the top of your manifold and lets identify what port connects to what. Typically, the PCV valve and distributor vacuum advance connect to the carburetor. Fitting on the front of the manifold include coolant temperature gauge sensor (water passage) and heater core input (water passage) and on the rear power brakes (vacuum passage) and tranny modulator (vacuum passage). I believe that a Performer only has one vacuum port on the rear, so if you have PB and a C4, you will have to tee it to feed both.
Old Apr 20, 2009 | 06:06 AM
kalli's Avatar
kalli
yes. performer has 1 port in rear, performer rpm has a 2nd port in the high rise part. had to learn it the hard way when i ran my engine with that thing open :-) took me a long time to find that leak *g*
Old Apr 20, 2009 | 04:48 PM
Joe67's Avatar
Joe67
Banned
thanks mark, that solved my problem.
i was confused because stock had 3 ports
and edelbrock had 4... 2 in the rear on intake runners, i guess dual vacuum, and since i have manual brakes then one should be plugged?
Old Apr 20, 2009 | 05:43 PM
fakesnakes's Avatar
fakesnakes
Exactly!
Thunderball
15
Nov 22, 2015 11:49 PM
legendlime
Jun 30, 2006 07:16 PM
Shifty5.0
Jun 29, 2006 11:25 PM
Oct 6, 2004 06:01 AM
