Tachometer
Old Apr 26, 2009 | 09:25 PM
Tomrob77's Avatar
Tomrob77
Default Tachometer
I was going to install an after market tach tomorrow onto the steering column. My car doesnt have a stock tach (68 coupe) Is there any tutorial anywhere or a video or even wiring diagram of where i have to connect the wires?
Old Apr 26, 2009 | 10:52 PM
rst08tierney's Avatar
rst08tierney
simple. if its a single wire tach, connect it to the negitive post on your coil
Old Apr 26, 2009 | 11:02 PM
cfd2bc's Avatar
cfd2bc
If you know the manufacturer, look them up. They all probably have a pdf manual on how to hook it up. If not, rst is right single wire to neg. Mine has red to 12v on with the key, black to ground, white to lights and green to neg side of coil.
Good luck.
Old Apr 26, 2009 | 11:04 PM
Tomrob77's Avatar
Tomrob77
so this now involves me opening up my dash correct?
Old Apr 27, 2009 | 08:41 AM
urban_cowboy's Avatar
urban_cowboy
The negative post thing works if you are still running points. If you have switched to electronic ignition like MSD, you need a tach converter in between the coil and the tach.
Old Apr 27, 2009 | 10:15 AM
wumarshall82's Avatar
wumarshall82
you probably dont want to open your cluster up unless you want the wires running out of it. I just ran my wires down my steering column and wrapped them in black coating to match the dash. It took about 20 minutes to hook up.
Old Apr 27, 2009 | 10:39 AM
1971mach1's Avatar
1971mach1
We don't need no steenking points!
The negative post thing works well with the Pertronics points eliminator kit too.
I went with a black mini-tach attached to the steering column and it almost looks stock.
No "dash opening" just blue to coil, red to 12v relay, white lights, and black ground.
Old Apr 27, 2009 | 11:23 AM
wumarshall82
btw, make sure you test it outside of the car to make sure it works before running all your wires, ect.
93rustanglx
Sep 20, 2006 10:36 AM
elmustang5.0
Jun 17, 2006 12:55 AM
fle5141181
Jun 7, 2006 12:59 PM
cletusboyer
Feb 10, 2006 12:41 AM
92FordGt
Oct 31, 2003 09:35 AM
