Find the problem :-)
Old Jun 22, 2005 | 01:26 PM
michaeldoggrell's Avatar
michaeldoggrell
Default RE: Find the problem :-)
KTM Quote:
You have nice project engine. It seems that your ignition coil is located on the intake manifold and I hope that it is bolted with intake bolt. Usually coil is located front of the engine and bolted front of the cylider head. In my ยด68 coil is at drivers side cylider head and this car is w/o a/c. Picture withc "Soaring" did send coil was located other side but in his car a/c compresor is at driver side so there is no room enough for coil.
Yep the ignition coil is bolted with the intake bolt.
KTM Quote:
And last but not least: you have leaking carb and ignition coil right next to it. Be careful that you wont burn your Mustang
Why do you think it is leaking. I let it run for a while, I driven the car but i did not see any leaks.
6mustang6 Quote:
Does your car have power steering?
Yep it does, and its the only part of the stang that is loosing oil. Just a drop a day.
Does anybody know where i can get a good replacement carb ?
Old Jun 22, 2005 | 02:03 PM
Soaring's Avatar
Soaring
I ♥ Acer
Pony carbs has a great reputation. So, try there. Oh, and that white box on the right front corner of my engine bay is the reservoir for my radiator. Originally, the 65's and 66's didn't have that. I'm not quite sure when Mustang started putting those on.
Old Jun 22, 2005 | 02:20 PM
Scott H.'s Avatar
Scott H.
1). Vent for float bowl. This does not hook up to anything and needs to be open and clear of any debris, otherwise there will be drivability issues.
2). Steel pipe originally went to a Vacuum operated brake booster. You may not have this on your car.
You need:
1). hook up vacuum line to modulator on Transmission so that car will automatically down shift when engine is under load at lower rpms
2). Remove steel vacuum line and save for later if you add power brakes. Cap off threaded seat by tapping a pipe brass plug to to the proper thread (probably about 16tpi).
You may also need to make adjustments to the vacuum modulator, I would highly recommend either the factory manual or a good book on C4 transmissions.
I agree with Soaring about Pony carbs, pretty decent product.
Are you in Belgium?
If you are, I am envious. That is a beautiful country.
Good luck,
Old Jun 22, 2005 | 02:46 PM
michaeldoggrell
You need:
Are you in Belgium?
Ok so if i understand this correctly, the way that the vent for the float bowl is setup is normal, its open so nothing needs to be fixed there
But the vacuum line is cracked. I saw some openings in the line so i guess it's not a vacuum line anymore
By the way, where do i find pony carbs ?
=> And yes, I live in Belgium, its a beautifull country but too few mustangs ... we can't even get the new one here, and if you can get one ... they are sooo danged expensive.
50.000 euro's + crazy taxes. Oh well I got my '66 ... i'm happy
Old Jun 22, 2005 | 02:47 PM
6mustang6's Avatar
6mustang6
I was wondering because i saw the belt going that way. That steel line Scott was talking about goes to the transmission moduler. At least on my 66 it does.
Old Jun 22, 2005 | 03:02 PM
Soaring's Avatar
Soaring
I ♥ Acer
Here is the addy for Pony Carbs. I was stationed in Germany for several years, and I don't remember ever seeing a classic Mustang in all of Europe. I know there are some there, but they must be scarce as hen's teeth.
http://www.ponycarburetors.com/
Old Jun 22, 2005 | 03:34 PM
KTM's Avatar
KTM
ORIGINAL: michaeldoggrell
KTM Quote:
KTM Quote:
Well when I look picture and I see brown all around carb I think there is or there has been major gasoline overflow. Gasoline and dust togehter will make that kind of dirt and you have that dirt quite lot. It is flameble and when you have old car, old electricity and old carb it is point to be careful.
Usually those carbs are good and you dont need new one. You can rebuilt it with master kit and if it is Holley carb you can order master kit by LIST number. LIST number is in choke tower (LIST 12345-6).
Old Jun 22, 2005 | 04:18 PM
Scott H.'s Avatar
Scott H.
I would take 6Mustang6's word for the steel vacuum line. he's got one.
6Mustang6 is your's bent like that??
Looks like it should be facing towards the bell housing. Maybe it's just a matter of loosening the line and turning it so it points that way.
Also is yours that short? I thought the steel line going to the transmission went almost to the vacuum modulator.
Michaeldogrell, you can replace the vacuum hose. Get a plug for where they have looped it back to the intake manifold, and run it to the vacuum modulator. this will make a big difference in drivability.
Old Jun 22, 2005 | 09:30 PM
6mustang6's Avatar
6mustang6
Yes, Mine looks exactly like his, It has a bend in it, then it bends upward. There the rubber line connects to it. SO his is fine by looking at it. I would love to answer anymore questions about it so if you need me, you know where the thread is.
Old Jun 22, 2005 | 11:02 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: KTM
KTM Quote:
KTM Quote:
Nah, that ain't from a leaking carb. At least not any excessive leaking. Look at any daily driver carb, and that brown crap is on them. That's a natural phenomen with carburetors.
