Carb Fuel Problem
Old May 1, 2009 | 08:46 PM
elliott65's Avatar
elliott65
Default Carb Fuel Problem
Just rebuilt 289 and 2100 Autolite carb. When test driving the car will run out of fuel if I run over 40 mph, I can feather the gas and keep it going. I pulled over and shut down and took top off the top of carb and the bowel was only 1/2 full. Started car up to see if float needed adjusted and it was fine at idle, bowel filled up to 1/4" from top. Took new fuel pump canister off and it was full with clean fuel and cartridge clean. Could I be vapor locking? Other than replace new sending unit in tank,or new fuel pump don't know what to try. Any help is great.
Old May 1, 2009 | 09:50 PM
67mustang302's Avatar
67mustang302
Fuel pump for float level, or a clog/kink in a line somewhere.
Old May 2, 2009 | 09:05 AM
67t5ponycoupe's Avatar
67t5ponycoupe
Did you replace the fuel filter?
Old May 2, 2009 | 12:38 PM
elliott65's Avatar
elliott65
I installed new pump and canister with new filter and tank sending unit with sock. I don't have an inline filter. How can I check fuel pressure to carb?
Old May 2, 2009 | 05:15 PM
kalli's Avatar
kalli
you can check that only with an inline fuel pressure gauge. they're quite cheap. get one for carbs. 0-15psi max
musnicki
Sep 23, 2015 07:11 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
cbird1177711
Sep 2, 2015 08:51 PM
SYNY5TER
Sep 2, 2015 01:35 AM
