hole in 302 block
That hole belongs there. You weld it closed and your cam/distributor gear will burn up. That hole channels some of the oil from the lifter valley over the cam/dizzy gears, along with the front oil return holes from the heads. It helps keep them cool. If it looks broken it's because nothing needs to move through it, it's non machined, and as a result has very rough casting, sometimes rough enough to cut your finger on.
Yeah, nothing wrong with cleaning it up if you want to. Not necessary though. If you do, just make sure you clean the block really well, you don't want crud getting into the lifter galleries because it could jam up your lifters.
jwog666
Dec 27, 2021 08:09 PM
