Did it really take 3 threads to come to this resolution?
Every thread you past gets the same feedback, must not be what you want huh?
everything about these cars is gonna require a good bit of work
no, IIRC it will go right in, no problems.
do you know what heads it has by any chance, thats the only problem could be if you have gt-40 P heads ( the headers are very expensive)
This is a Ford Racing 5.0 'crate motor' installed in a 67 coupe, that started out as a 6 cylinder. The engine uses all the belts, brackets, PS and pulleys stock for a 67. A special damper, and if you use stock clutch linkage a small clutch adapter are pretty much all you need, it's really as easy as putting in a stone-stock 67 289.
