Sheet metal question
Old May 15, 2009 | 04:49 PM
SJs 66coupe's Avatar
SJs 66coupe
Default Sheet metal question
I have a fender apron that I bought a week ago. Not painted when bought and is already starting to develop just a hint of surface rust.
Should I go ahead and clean the metal off then prime it now or will this interfere with spot welding it in a couple of weeks from now?
Old May 15, 2009 | 04:53 PM
jcoby's Avatar
jcoby
you want bare metal where you weld or weld-through primer if you're welding somewhere you can't get back to later to prime. cleanliness is extremely important to weld quality.
it won't hurt to prime it now but wherever you weld will need to be cleaned before welding and then re-primed.
Old May 15, 2009 | 05:01 PM
groho's Avatar
groho
I guess the answer depends on access to the panel. how easy will it be to finish the panel once it's welded in? both sides? what good is a rusted panel? I'd say clean it up, and buy some weld through zinc primer to protect it until you actually weld it on.
Old May 15, 2009 | 11:14 PM
109jb's Avatar
109jb
That little bit of surface rust will just wipe right off with metal prep. Metal prep is a dilute solution of phosphoric acid and the rust will just be gone. When you get ready to weld it, just wipe it with metal prep and then wipe again with acetone and you will be fine. Shoot a little weld through primer on the part that laps and you won't be able to get to.
Old May 16, 2009 | 09:05 AM
trashline's Avatar
trashline
if its gonna sit for a while Id get something on it, wd-40, paint, or something else.
i second the weld thru for hidden areas.
Old May 16, 2009 | 10:21 AM
109jb's Avatar
109jb
If it is just surface rust and it is sitting inside then it won't matter. The metal prep will take the surface rust right off. I'm quite sure it will take all of that little surface rust off, but if any does remain it will neutralize it.
mungodrums
Sep 28, 2015 10:54 PM
treesloth
Sep 28, 2015 07:03 AM
Ghost_Conscience
Sep 23, 2015 02:17 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
