Finally PROGRESS!!
Old Nov 8, 2011 | 12:49 PM
  #61
90RunnerRed's Avatar
90RunnerRed
Originally Posted by tx65coupe
I'm glad to see your back at it. I would go with a T5, but there is nothing wrong with keeping rebuilding the 4 speed. I think if your pateint and pay close attention to what your doing, rebuilding the 4 speed yourself will work out fine.
If your staying with the stock engine, I'd go with 2.25 inch or 2.5 max and some Dymomax Ultraflow or Super Turbo mufflers, or maybe Magnaflow.
There is no point to running 3 inch exhaust on even a mildly built motor. Also, I've had Flowmaster on more than a few vehicles over the years, and I'll never do it again. The hollow tin can sound and droning is terrible. I had them on my 65 for 6 months and that was enough for me. It has Ultraflows now and everyone thinks it sounds better.
The exhaust that was on there was 1 5/8". So pretty much anything is going to be an improvement. I agree about not going too big though. Thanks for the muffler suggestions.
Old Nov 8, 2011 | 12:58 PM
  #62
90RunnerRed
Originally Posted by frdnut
Another vote for a T-5..They work great and are pretty easy to install..
That's actually the way I'm kind of leaning. I just need to do my research now and figure out the cost versus benefit.
On the subject of finding a T5 though, I know the best way would be to find one still in a car so I know the car condition, mileage, ect. But is there anyway to get a good idea of the health of a unit that is not in the car?
Old Jul 22, 2013 | 09:28 PM
  #63
90RunnerRed
Well....almost two years later I'm finally getting back at it. We had our first daughter about a month after the last post, so needless to say I've been a little distracted.
Decided to rebuild the original T10, did a lot of thinking about how I want to use the car and what I want it to be and that led me to rebuilding...
Engine prepped and loaded up, I dropped it off at the machine shop today after work. He said roughly two months to finish it, will know for sure once he tears it apart. All I know is I'll need all of that time to complete the shopping list and get all of the odds and ends done. Spent a couple hours cleaning the engine bay, really need to just push it out of the garage and power wash it.
Old Jul 27, 2013 | 03:22 PM
  #64
90RunnerRed
First of what I'm afraid is going to be a few shipments from the parts store:
- Engine Mounts
- Transmission Mount
- Choke tube assembly
- Speedometer cable
- Upper and Lower Radiator Hoses
- Engine Wiring Harness
- Alternator Wiring Harness
- Lower Shifter Boot
- Upper Shifter Boot
- Shifter boot hardware
- Adustable Clutch Release Rod
- Clutch Fork
- Clutch Boot
- Equilizer Bar Rebuild Kit
- 2 Apron Bolts to replace a couple broken ones
Old Jul 28, 2013 | 09:10 PM
  #65
90RunnerRed
Spent some time cleaning some stuff up today. Degreased, sanded, and primed:
Old Jul 28, 2013 | 09:16 PM
  #66
90RunnerRed
I took the voltage regulator cover off to repaint it, the gasket pretty much disintegrated when I did. Looking online I can find the gasket with a new cover, but not just the gasket. Anyone know where I can get one? Or is making my own the only option past buying the new cover?
Old Aug 4, 2013 | 03:10 PM
  #67
90RunnerRed
Got the final coat of semi-flat black engine enamel paint on some of the accessories today:
Horns came off and got prepped/sprayed:
Starter in the process of getting a fresh coat:
Old Aug 4, 2013 | 03:12 PM
  #68
90RunnerRed
Fuel pump cleaned up:
Checked the filter, must have been replaced by the previous owner, it looks good:
Old Aug 4, 2013 | 03:15 PM
  #69
90RunnerRed
Engine and headlight wiring harness' removed, I didn't want to have to buy new ones yet, but they are very brittle and it beats running the risk of starting a fire:
Engine bay pretty much stripped and ready for a power wash, next step is to prep it and give it a good coat before the engine goes back in:
Old Aug 4, 2013 | 03:27 PM
  #70
90RunnerRed
Original color of the car, someday it will be again, that's a long ways off:
