Finally PROGRESS!!
Old Jun 7, 2009 | 06:39 PM
  #41
90RunnerRed's Avatar
90RunnerRed
Originally Posted by tempoffroad
mine has a bolt that is under the motor near the alt. it has the ground for the alt that shares the same stud
Thanks for the help, I found the bolt you were talking about.
Old Jun 7, 2009 | 06:40 PM
  #42
90RunnerRed
Originally Posted by retro77
Is that a Global West lower control arm? I ordered up the lower and uppers from them. They are beafy!
No, it's just an oem replacement that came in a full suspension kit I bought from LMM.
Old Jun 7, 2009 | 06:45 PM
  #43
90RunnerRed
Originally Posted by boogerschnot
Why didnt you just get a bud, or in my case,, the old lady to pump the brake pedal while you bleed the system?? Its cheaper than buying a bleeder pump..
Well my whole reason for wanting to use the pump first is that I didn't have a bench bleed kit for the master cylinder and the parts store didn't have one either. I had read that you could damage the MC if you didn't bleed it first.
I will be using the pedal method to finish them off, I agree, much easier.
Old Jun 7, 2009 | 06:48 PM
  #44
90RunnerRed
Originally Posted by tx65coupe
Thats awsome!!!
Yeah we just bled the brakes the old fashioned way.
There should be a bolt or bolt hole on the lower front passenger side corner of the block that is a where I would put the ground.
The oil sending unit your talking about is shaped odd, but a socket will fit it.
Woohoo, I figured out how to multi-quote!!! Sorry, it's the little things that get me going.
Thanks for the comment as well as the help on the oil sending unit. My problem is the only socket I have that is big enough to fit the sending unit is an impact socket, so it has a really thick wall and won't fit in there. Guess this is a good excuse to buy another set of sockets.
Old Jun 7, 2009 | 06:52 PM
  #45
90RunnerRed
Originally Posted by LynnBob Mustang
Looks great!!
Did you put in a power brake booster or is it just the single small master cylinder?
Lynn
No booster, but I did get the dual bowl master cylinder. I was told I couldn't go with both the booster and the dual bowl since it is a 4speed (z-bar interference?). So I opted for the safety of the dual bowl. I never really minded the manual brakes anyways.
Old Jun 7, 2009 | 10:02 PM
  #46
90RunnerRed
It started!!!! Got everything hooked up and cranked it for about 3 seconds and then fired up! Huge relief given that I had never actually heard the engine run before. All that's left is to connect the clutch linkage and get an alignment!
Old Jun 8, 2009 | 04:47 AM
  #47
4reboy's Avatar
4reboy
very nice!
Old Jun 8, 2009 | 05:48 AM
  #48
LynnBob Mustang's Avatar
LynnBob Mustang
I'm looking into getting a '65 that is almost a twin looks wise to yours except it has a black interior.
It was once a sixer with drums and it will be switched to a V8 with disks, so I wondered if I could just leave it manual brakes.?.
Lynn
Old Jun 8, 2009 | 07:07 AM
  #49
tx65coupe's Avatar
tx65coupe
I converted mine from an I6 to a V8 with 4 wheel disc. Its front Granada and rear Versailles. It has a dual reservior master cylinder but is still manual brakes. It functions well, and I am happy with it.
  #50
tx65coupe's Avatar
tx65coupe
SWEET!!!
Its always good to hear someone say its running again. I never get tired of hearing that one.
