68 coupe suspension questions
I have a 68 "T" code coupe that I am going to put a 302 in. Last week I replaced upper and lower control arms, strud rods and bushings, swaybar links, springs, and shocks. The replacement springs are TRW "Standard stiffness" springs (whatever that means) for a V8 car. After replacing everything, the front end of the car sits at least 4" higher than before. I haven't replaced the I6 with the 302 yet, but even with the V8 I think this thing will sit too high. Tuesdqay I plan on removing everything and doing the "Shelby Drop" on the upper control arms. My question is....do I need to cut some of the spring off too? Will it settle in at all or will it still sit high? The leafs and rear end will be replaced when I drop the V8 in, but that is an issue I will deal with when the engine is done.
Thoughts or suggestions?
Thanks,
Thanks,
Wait until you have drove it some to cut the springs, anytime I have mine on a lift when I set it back on the ground it will sit high on the front end at first. The suspension has to have some time to settle.
uberstang1
09-20-2015 06:42 PM
09-08-2015 11:50 AM
