Suspension Reassembly
Old Jun 1, 2009 | 11:08 PM
badazz68stang's Avatar
badazz68stang
Default Suspension Reassembly
so i've got all the old suspension out and i mean all of it. Already drilled the new holes for the shelby drop as well. So now laying around the car i have new UCAs LCAs coil springs, tie rod ends, idler arm, shocks, sway bar, and a new disc brake swap kit. My question is, what should my reassemble order be. CAn i put the arms and the coil springs in first and still pick up the uca far enough to fit in the new spindle? Just trying to plan this out logically. thanks guys.
Old Jun 1, 2009 | 11:14 PM
Deviousfred's Avatar
Deviousfred
i would say you want to have your UCAs, LCAs, and spindle all mated before installing the coil spring and of course the shock after the coil. Strut rods and Sway bar could go on next. Steering components can go on after you've got all the suspension on. And brakes could go on last.
Old Jun 1, 2009 | 11:27 PM
badazz68stang
thanks fred, pretty much my thoughts exactly, i think i may search around for a better spring compressor tomorrow. the kind i have doesnt fit in the shock tower very well, its the claw type that you put the two different compressors on across from each other.
Old Jun 1, 2009 | 11:31 PM
badazz68stang
also, i am unsure of how to torque down the LCA bolts, since i read that that is where the caster is adjusted. It is the bolt that goes through the washer at an offset towards the top of the washer. Anybody know what im talking about?
Old Jun 2, 2009 | 10:41 AM
badazz68stang
bump, anyody else?
Old Jun 2, 2009 | 10:45 AM
1slow67's Avatar
1slow67
ROTM Moderator
I do know what you are talking about.
Old Jun 2, 2009 | 10:47 AM
2+2GT's Avatar
2+2GT
You need one of these, very similar to the ones used by Ford dealers, very quick and safe:
Old Jun 2, 2009 | 12:31 PM
badazz68stang
know anywhere to get one of those compressors? anybody on here have one they want to let me rent? haha.
Old Jun 2, 2009 | 12:56 PM
1slow67's Avatar
1slow67
ROTM Moderator
Autozone should have this one. My friend and I have both used it and had no problems with it. Worked great.
baddog671
Jul 26, 2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
