Question about my engine.
Old Jun 8, 2009 | 03:15 AM
Stangman70's Avatar
Stangman70
Hurray for mustang forums, and another problem solved!
Old Jun 8, 2009 | 08:29 AM
jcoby's Avatar
jcoby
Originally Posted by BA Mustang
289 uses a 302 block I believe.
i think that's true for '68 and later blocks. before that they were two different engines - the 302 had a little longer cylinder than the 289.
Old Jun 8, 2009 | 08:35 AM
2+2GT's Avatar
2+2GT
Exactly right, the cylinder extended about 1/8" farther down into the crankcase.
Old Jun 8, 2009 | 08:38 AM
2+2GT's Avatar
2+2GT
Originally Posted by Stangman70
Too true, although I can't think of many people who would put 289 heads on a 302 block, but I suppose its possible.
Since the 289 and 302 heads were virtually identical, and even Ford put 289 heads on 302 blocks, in fact many late 67 and 68 289 engines used a 302 block to build 289 engines, as they were being phased out.
Old Jun 8, 2009 | 08:46 AM
2+2GT's Avatar
2+2GT
Originally Posted by 68MustangCoupe
1968 Ford Mustang 302: Rusty True Duels, Unknown style of old aftermarket Rims... the Cap just has an A on it.
Stands for Appliance, and was a bargain brand. Actually, they were pretty good. A friend of mine had the imitation 'Cragar' all-steel wheels on a 70 1/2 Formula 400, and my brother still has his aluminum slots on a dune buggy. 35 years is pretty good for a 'bargain brand'.
Old Jun 8, 2009 | 09:46 AM
jcoby's Avatar
jcoby
Originally Posted by 2+2GT
Since the 289 and 302 heads were virtually identical, and even Ford put 289 heads on 302 blocks.
I'm pretty sure the 289, 302W, and 351W (post-73-ish?) heads can all be exchanged. The 351W heads have a larger hole for the bolts but they're otherwise identical to the 302 heads. Seems like the early 351w heads had a different intake and don't match the 302 intake.
I've got a late model roller 302 that I'm considering using either my 289 or 351w heads on since it came with the infamous e6te heads.
Old Jun 8, 2009 | 02:47 PM
JMD's Avatar
JMD
There has been what I consider an old wives tale that 302 cylinders are supposed to be .020 longer than the 289 cylinders, people who have ACTUALLY measured have have stated that 289 & 302 cylinders are the same length....
Even if true, WTF will .020 longer cylinders do for an engine anyway.... (this is 2/10 of 1/10th,,, )
If your car is a coupe, the engine swap won't reaaly make a difference as far as value of the car is concerned, it will probably make some difference if the car is a fastback...but it wouldn't mean much to me because to me cars are meant to be driven....
Old Jun 8, 2009 | 10:35 PM
68MustangCoupe's Avatar
68MustangCoupe
Thanks for the info
-If your car is a coupe, the engine swap won't reaaly make a difference as far as value of the car is concerned, it will probably make some difference if the car is a fastback...but it wouldn't mean much to me because to me cars are meant to be driven...-
And it really doesn't matter if it's a swap as long as it is in fact a 302. which has been confirmed by a friend. The Value is meaningless to me... I paid 1600 for it, and I'm not about to sell it anytime soon as I've been wanting one of these for some time it's not getting sold.
Thanks people!
Old Jun 8, 2009 | 11:25 PM
JMD's Avatar
JMD
Sounds like you got the car for a great price... ENJOY!!
GimpyHSHS
19
Dec 19, 2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
UrS4
Sep 30, 2015 10:13 AM
Drastang
Sep 30, 2015 03:48 AM
treesloth
Sep 28, 2015 07:03 AM
