c4 trans.. need help
Old Jun 26, 2009 | 04:03 PM
digitalhero2's Avatar
digitalhero2
Post c4 trans.. need help
hi i gotta problem with a c4 trans.. well i recently rebuild it put it back in and for some reason there was like a huge leak from rear casing gasket. so i took it back out looked at it and its not ripped.. nuthing. everything looks fine..
do u think if i tighten the band to tightly it can cause fluid to shoot out like that .. cuz it only does it when im n 1 gear or R.. which it has to be something with the rear pack or band. or could it that it had to much fluid n the casing... thanx
Abel.
Old Jun 26, 2009 | 11:15 PM
rst08tierney's Avatar
rst08tierney
How many lbs of torque did you use
Old Jun 27, 2009 | 12:25 AM
Randys66gt's Avatar
Randys66gt
Don't torque them!!!! Tighten them down till snug and on the intermediate band, back it off 1 3/4 turns. Back the low-reverse out 3 turns. Torquing them will break the bands. At least halk the calls I got at B&M were because people didn't READ the instructions. Most of the torque settings are inch pounds, NOT foot pounds!
Check the low-reverse band cuz it does sound like it is too tight.
Old Jun 27, 2009 | 12:28 AM
Randys66gt's Avatar
Randys66gt
Oh yeh, also check to make sure the vent isn't plugged or that would also cause the fluid leak. Most likely isn't that because it would cause fluid leak in all gears but it's something else to make sure is in good shape.
Old Jun 27, 2009 | 12:06 PM
digitalhero2
ight thank u soo much ya found out about the whole 1 3/4 turn out thing yesterday n a book and the rev. is 3 full turns kewl thanx.. ya ill check the vent too hope its not pluged.. thanx again..
65vertable
Jul 6, 2011 03:55 PM
ward_spratlin
Apr 27, 2011 09:47 PM
cali4.6
Jan 19, 2010 10:36 AM
F150 StrokerCobra
Sep 10, 2009 12:22 AM
rex7010
Apr 13, 2006 01:08 AM
