holley carb #
Old Jul 5, 2005 | 02:52 AM
markrazz's Avatar
markrazz
Default holley carb #
heres the holley carb numbers of the carb 80457-2 and below these numbers 3509..does this tell anyone what carb i have and how to dial it in ..ty
Old Jul 5, 2005 | 11:20 AM
1970 mach1's Avatar
1970 mach1
Default RE: holley carb #
Call Holley they have a very good hot line and will be glad to help you.
Old Jul 5, 2005 | 03:38 PM
nualln's Avatar
nualln
It should be a holley 4160 600 cfm 4V, from what Ive googled.
Take a look at this chart.
http://www.holley.com/data/TechServi...%20Listing.pdf
yours is the last listing on page 15. It will tell you what size power valves to get, as well as which rebuild kit to buy.
This manual will tell you how holley's work, and how to tune them:
http://www.holley.com/data/TechServi...ech%20Info.pdf
You'll need a vacuum gauge which you can buy a sears or napa/pepboys/autozone/orielly for about 20 bucks.
Old Jul 5, 2005 | 06:12 PM
vfast's Avatar
vfast
I ♥ Acer
trail and error if you have a bigger cam then a different power valve is need or you might need a different sec spring to get rid of a bog...remember a holley in stock form is just a start..thier great carbs because there is alot you can tune on them to tailor them to your car
bradleyb
Nov 27, 2015 07:50 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
Wombatnation
Sep 13, 2015 09:16 PM
