When does stall lock up?
Old Aug 12, 2009 | 11:38 AM
interwest's Avatar
interwest
Default When does stall lock up?
If the trans is in 2nd or 3rd gear is the stall locked up? Or can it still be spinning free if under the advertised rpm?
Old Aug 12, 2009 | 11:55 AM
Randys66gt's Avatar
Randys66gt
When you are under acceleration and above the rpm, it is locked per say! It is a fluid lockup, not a clutch lockup like the 94+ trannies.
Old Aug 12, 2009 | 12:25 PM
interwest's Avatar
interwest
So I have 2500 stall. In third if I am cruising under 2500 will there be an overheating problem because it won't lock up?
Old Aug 12, 2009 | 12:38 PM
urban_cowboy's Avatar
urban_cowboy
Here is an excerpt from wikipedia.
The maximum amount of torque multiplication produced by a converter is highly dependent on the size and geometry of the turbine and stator blades, and is generated only when the converter is at or near the stall phase of operation. Typical stall torque multiplication ratios range from 1.8:1 to 2.5:1 for most automotive applications (although multi-element designs as used in the Buick Dynaflow and Chevrolet Turboglide could produce more). Specialized converters designed for industrial or heavy marine power transmission systems are capable of as much as 5.0:1 multiplication. Generally speaking, there is a trade-off between maximum torque multiplication and efficiency—high stall ratio converters tend to be relatively inefficient below the coupling speed, whereas low stall ratio converters tend to provide less possible torque multiplication.
It is a good article.
http://en.wikipedia.org/wiki/Torque_converter
Old Aug 12, 2009 | 08:17 PM
gothand's Avatar
gothand
FWIW, the torque converter in the C-4, C-6, et al, is of the non-locking variety. If the OP is talking about the newer cars in the sig, then those trannies lock up, though not in all gears.
Old Aug 13, 2009 | 12:21 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
stall speed depends on the torque the motor is putting out, its not locking up unless you have a non stock tranny in your classic
Old Aug 13, 2009 | 06:27 AM
2+2GT's Avatar
2+2GT
Exactly. Older converters don't "lock" at all.
Dathan
Oct 5, 2015 05:52 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Sep 25, 2015 06:58 PM
