Comp engeering slid a link
Old Aug 19, 2009 | 12:14 AM
Mustang68cp's Avatar
Mustang68cp
Default Comp engeering slid a link
I installed a set of comp eng slid a link traction bars on my 68 mustang coupe.Ive noticed that a lot of other guys are using cal trac on there car. Just wondering if anyone has had any luck with the slid a links mine work great. or if the cal tracs are better and i wasted my money???
Old Aug 19, 2009 | 09:43 AM
cprstreetmachines's Avatar
cprstreetmachines
Wouldn't say a waste. Have seen guys go fast with them. Caltracs I think are better though. Slide a links you can't move the instant center at all, only change pre load.
Old Aug 19, 2009 | 01:03 PM
Adrenolin's Avatar
Adrenolin
Not sure about the Cal Tracs but the Comp Engineering slide-a-links do not fit the 4.5 leafs. Just to be aware of...
Old Aug 19, 2009 | 09:38 PM
cprstreetmachines
Damn, that sucks. The caltracs will fit any thickness. Just need to make sure you get them for the correct setup. Mid eye, rev eye, standard etc.
Old Aug 20, 2009 | 12:41 AM
Adrenolin's Avatar
Adrenolin
It does. The problem is the stock setup only has the single leaf coming back to the eye but the 4.5 has a double leaf going back. The 2nd spring from the top comes back farther and will not fit into the spring eye bracket as its designed for only the top single leaf height. I have to remove them soon as I cant wait on CE and don't have the time to fix it myself.
I've called CE 5 times now talking to their design guy requesting a bracket to support the extra leaf. Each time I call he says he'll have to look into it further and will get back to me. I never hear back from him. It just needs an extra 1/2" along the top of the bracket to give the extra 1/4" needed for the 2nd leaf.
Great product for stock leafs but can't be used with 4.5s.
Old Aug 20, 2009 | 09:13 AM
cprstreetmachines
Just take out the two smaller bolts so it will fit. The smaller one will only help with brake hop, if you have it. Or just cut the leaf off. Won't hurt anything. The bars will keep the leaf from bending and wrapping up right there anyways.
Old Aug 20, 2009 | 11:21 AM
urban_cowboy's Avatar
urban_cowboy
I am running slide-a-links with 4.5 leaf springs and love them. I installed them 2 years ago, so I will have to look to see how I got them installed, but they work great with my 4.5s.
They are more forgiving than cal-tracs on the street, but still totally eliminated my wheel hop once they were calibrated for my torque. Slide-a-links, 4.5 leaf springs, rear sway bar, and some good MT tires will get you planting the power on the street for sure.
Old Aug 20, 2009 | 01:29 PM
Adrenolin's Avatar
Adrenolin
Urban.. I'd love to see how yours fit. As shown in the pic above is how they are currently on our car and of course its wrong. Just no way in getting those 2 leafs in that slot as it's just the thickness of 1 leaf.
CPR.. that was my first though however while playing with it the lower plate (where the arrow is pointing to) is welded in. Cutting it off and welding it lower winds up with that large bolt in the way.
By all means suggestions are welcome... This wasn't meant as a thread hijack btw.
Old Aug 20, 2009 | 08:45 PM
cprstreetmachines
I wouldn't worry if you didn't have that plate or a bolt there. Never had my caltracs brake hop, and they don't have them.
Old Aug 20, 2009 | 10:29 PM
Scott H.'s Avatar
Scott H.
