Stroking a 289?
Old Aug 20, 2009 | 08:40 AM
kadumel's Avatar
kadumel
What also gets me here is that the only difference in what I want to do and what it is now is the internals. The block will not be changed at all. To say that saving the virgin block is a good thing is kinda ludicrous because it has already been machined .030" over and it is not going to ruin the block or anything.
Old Aug 20, 2009 | 11:14 AM
Starfury's Avatar
Starfury
Well, I forgot one thing. The roller block is machined for a one-piece rear main seal , while the 289 is set up for a two-piece unit. You can machine the 289 block to accept a one piece rear main seal, but you'd have to do that in order to swap cranks between the two blocks.
Old Aug 20, 2009 | 01:14 PM
67mustang302's Avatar
67mustang302
Using GT40 heads you might as well build a 302. You won't get any more power out of a stroker, it'll just make the power at a lower rpm.
Old Aug 20, 2009 | 01:28 PM
kadumel's Avatar
kadumel
GT40 heads are just a set of heads I have for now. I plan on buying a better set of aluminum heads down the road of course.
Old Aug 20, 2009 | 01:56 PM
67mustang302
You need good heads to feed a 347.
Old Aug 20, 2009 | 03:51 PM
Starfury's Avatar
Starfury
While I completely agree, I ran some '68 J code heads with big valves, upgraded valvetrain, and port matched exhaust on my 331 until now. Worked fine until I finally picked up a set of Trick Flows.
Old Aug 20, 2009 | 04:08 PM
67mustang302
It'll run fine, there's just no sense in spending money on a stroker kit when you have a crank and rods that will work. If you plan on upgrading heads later, then yeah. A 347 though to really make some power needs some good heads.
Old Aug 20, 2009 | 09:15 PM
htwheelz67's Avatar
htwheelz67
even with crappy heads a 347 will make at least 50 ft lbs of torque more than a 289, probably 30-40 more hp if you didn't change a thing.
Old Aug 20, 2009 | 11:49 PM
67mustang302
It'll make more torque at a lower rpm, so the horsepower peak is lower also, but the horsepower is generally about the same. The smaller engine needs more rpm to make the horsepower(less torque) so it needs more gear also. The 347 will run better at lower rpm though.
uberstang1
Dec 7, 2017 07:10 AM
GTJIM
Sep 23, 2015 09:59 AM
ryland
Sep 13, 2015 12:35 PM
Brian Emmer
Sep 9, 2015 02:50 PM
ding56
Aug 14, 2015 02:40 AM
