Took the carb off to start rebuild
Finally got around to taking the carb off to replace the accelerator pump and rebuild. But when I changed the pump the old one didn't look bad it almost looked like the new one. So now i'm stuck again on if that wasn't the problem what is? I haven't put it back on and tested it yet so should I start the rebuild or see if the pump was the problem?
Also how hard is it to rebuild a carb? Because it came with a diagram but it doesn't have like instructions just shows a picture of the carb in pieces. I'm 17 and don't know much about carbs so I wasn't sure if I would be able to do it.
Thanks
Thanks
my dad had his 850cfm holley double pumper rebuilt for $120, that includes all new seals and whatnot, sandblasting the whole casing, reassembly, and everything else that goes with the rebuild. It came out as a BEAUTIFUL piece, if you are unsure how to rebuild a carb then just farm it out. I personally haven't rebuilt a carbs so all I can say is if you do it take it nice and slo and place everything out in order. That carb looks like it can use a rebuild but the choice is up to you.
It's easy to just put the carb back on and see if it fixed the problem before rebuilding it.
Other than that, sorry I had no luck either to rebuild a carb or having one rebuilt. Ended up buying a new Edelbrock, it runs great 2+ years. No more rebuilds for me, may as well flush the money down the drain IMHO. These old carbs weren't ment to run on modern gas additives, probably why the pro-rebuilt one failed in 6 months too. Edelbrock site says their carbs are compatible with modern gas.
since this is your driver, farm it out and get it done right. Suggest going to a bone yard and picking up a similar carb or have a friend give you one to rebuild. Most non-corporate bone yards would be happy to sell you a rebuildable carb for pocket change. Then you can take your time doing it. Once you've gotten past the fear factor you'll have a better understanding of what goes where, and how to put it back together. The hardest part is initial adjustment and setting everything up; float levels, jetting, idle, fast idle, choke, etc. Good luck.
Whenever I am taking something apart I try to take photos along the way. Doing this helps you get back home when its time to reasemble it. Also, take pics at every angle before you start pulling hoses and wires off. A good digital camera is easliy affordable!
Man only needs pictures to put things together. Whats this instruction stuff??
Get your self a Holley rebuild manual and a rebuild kit. You can do it if you can follow directions. It is not rocket science.
Check the Holley website:
http://www.holley.com/37-1536.asp
Check this page:
http://www.carburetion.com/books.asp
If you pay attention and follow the directions, you can do it in a weekend. Bench setting and adjustments are where it gets a little tricky, but again, the rebuild kit will coem with bench setting instructions. The Holley site has setting instructions as well, and any one of the holley rebuikld manauls will include adjustment information as well.
Good luck.
Check this page:
Good luck.
Well so far I have dumped like $50.00 into it and it still not run right and I don't really trust myself to rebuild it. So i'm saving up to get an edelbrock. But one of my friends suggested a demon I wanted one but their expensive. He said I should run a demon 650 so if I can come up with enough i'll probably go for that.
And I was going to try to start it and see if the pump fixed it but I put the carb back on and started the car and noticed I forgot to connect the accelerator linkage to the carb. So I turned the car off and put it on real quick but while trying to restart it the silinoid sparked and it won't crank or turnover. Replaced the silinoid and still nothing. My dad said it could have burned a cell in the battery so that it still reads voltage but not enough power the start the car. We are going to try to jump it off later and hopefully it works because I can't afford a new ignition system or anything right now.
A cell in my battery went dead, kragan said it was fine blah blah i knew it wasn't because I tried it on 2 cars. They ended up hooking it up on one of the workers dodge dart and it didn't start so they prorated a new one for me. This could very well be your problem, let's hope so! and hopefully your battery is under warrenty, or else it will be like 60-90 bucks
But the battery tray needs replacement bad! it's literally falling apart but I can't seem to get the bolts off. I have sprayed them with WD-40 like 5 times trying to loosen them but so far nothing. As a last resort I might have to drill them out.
The replacement
zanemoseley
09-06-2015 12:58 PM
