Turn signals... Again
Old Aug 26, 2009 | 06:43 PM
1966stang's Avatar
1966stang
Question Turn signals... Again
So, ive worked on my wiring for about 10 hours and still cant get it to work. So i ordered a whole new OEM switch and want to see if you guys could provide me with the correct info so i can see if that works. Ive posted this before and used the FAQ diagram to no avail. I messed the whole thing up by pulling out the wires in the plug with out remembering which went where. So if you could tell the matching wires for the plug. there are 6 wires that go into the steering column side and 9 wires that lead out on the gauge side. This plug is somewhere under the dash and leads from the bottom of the steering column up towards the gauges (you dont need to take anything apart to look at it). i have the correct wires on the side of the plug that goes to the gauges but need to know which wires go into the plug on the other side (coming from the steering column). If you could just let me know the corresponding wires to the colors below.
going around the plug(the one that leads to the gauges):
Yellow corresponds to ...
2 light green ...
light blue ...
very light blue(almost white) with yellow stripe ...
2 light green with white stripes ...
2 white with blue stripes ...
Sorry if this confused you, i tried to be as clear as possible. Thanks in advace for your help.
Mark
Old Aug 26, 2009 | 08:15 PM
2+2GT's Avatar
2+2GT
Strange. The color codes are supposed to match. Either your car is screwed up, or the switch is.
Old Aug 26, 2009 | 08:32 PM
capri man's Avatar
capri man
what he said!
Old Aug 26, 2009 | 09:09 PM
1966stang's Avatar
1966stang
well, the first switch i had was a cheapo import, didnt work (colors were different from the original)- i spent hours doing trial and error but couldnt get it to work. then i bought the original switch which will hopefully work with your help. its not the car cause all but the brake lights worked before. im really hopeing that it was the switch and that the new one will fix the problem.
Old Aug 26, 2009 | 09:59 PM
msmith's Avatar
msmith
Have you checked the tightness of your neg. battery terminal? I spent two days chasing taillight problems and thinking I had a bad turn signal switch until I tightened the neg. terminal on my battery and everything started working properly again. Worth checking, anyway.
Old Aug 27, 2009 | 07:34 AM
unit91's Avatar
unit91
My light problems were solved when I replaced the voltage regulator. Before I did that my lights were doing crazy things like turn signals worked until I applied the brakes, then brake lights came on and signals went out, and other weird stuff.
Old Aug 27, 2009 | 03:40 PM
1966stang's Avatar
1966stang
okay, im gonna try the neg cable and voltage regulator, btw where exactly is the voltage regulator??? I didnt even no that i had one. but ill still need the codes if any one could help me out there. Thanks for the help
Old Aug 28, 2009 | 10:43 AM
unit91's Avatar
unit91
Standing in front of the car it's to your right, next to the radiator. It's a box with a wiring harness plugged into the bottom of the box.
lincolnshibuya
Dec 8, 2015 04:37 PM
breaking
Oct 2, 2015 01:27 PM
ChampInSD
Oct 2, 2015 04:55 AM
Sep 30, 2015 12:39 PM
logan409
Sep 26, 2015 07:43 PM
