Transmission kickdown - what does it do?
Old Jul 8, 2005 | 09:35 PM
nualln's Avatar
nualln
Default Transmission kickdown - what does it do?
Ive been looking at carburetor parts, and I keep seeing Ford auto transmission kickdown.
What does it do?
Old Jul 8, 2005 | 10:12 PM
6mustang6's Avatar
6mustang6
Default RE: Transmission kickdown - what does it do?
The kick down is for the automatic transmission. When you floor the car basically, the transmission will kick up into a higher gear. like if your in 3rd, the tranny will kick into 2nd. likewise if it's in 2nd it'll kick into 1st.
Soaring's Avatar
Soaring
I ♥ Acer
Whenever you punch the gas pedal to pass, it throws the tranny in the next lower gear to create more power to pass. Used only on the automatics.
Old Jul 9, 2005 | 05:43 AM
65_2plus2's Avatar
65_2plus2
Cars of today use an electronic solenoid to tell the transmission that it needs to down shift. Not long ago transmissions used vacuum to determine when to shift down and in the older fords they a used mechanical linkage (kickdown) to force the transmission into the next lower gear.
Cheers [sm=icon_cheers.gif]
4cylinderplus2
Oct 9, 2020 07:45 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
wraith777
Sep 28, 2015 10:49 AM
