clear coat question
Old Aug 28, 2009 | 09:33 PM
rst08tierney's Avatar
rst08tierney
Default clear coat question
I had to repair some an area on my trunk. The repair came out great and I re-shot the trunk with clear. its still really fresh (about 2 hours) and small specks in the clear started to show. It looks like hell, almost like dust is under the clear in some areas. Will a really good wet sand fix the problem or is it time to back track after it cures?
Any ideas on what happend? Before I shot the clear I sanded the entire trunk with 1000 then 1200. The lid was shot in a booth to cut down on dust etc.
Thanks
Old Aug 29, 2009 | 12:52 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
is it dust or or like solvent trapped ?
Old Aug 29, 2009 | 01:02 AM
Canary94GT's Avatar
Canary94GT
You made sure to clean the trunk before painting?
Old Aug 29, 2009 | 01:13 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
well im wondering if hes having solvent pop, that comes from not waiting the proper imes in between coats
Old Aug 29, 2009 | 12:22 PM
rst08tierney
I thought I did. I must not have done a great job. I spent about 30min cleaning it up making sure it was ready for the clear.
Lokks like im going to have to take it down and shoot it again. should I start with 1000 or 1200.
Old Aug 30, 2009 | 04:32 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
600, no need to work hard :P
Old Aug 30, 2009 | 10:34 PM
Cruzzar's Avatar
Cruzzar
Are you using water base, if so you really have to make sure the moisture content has significantly evaporated before you clear it. If not using water base, it sounds like solvent poping from not waiting long enough also.
Old Aug 30, 2009 | 11:11 PM
JMD's Avatar
JMD
From what I read on another forum, it sounds like maybe the isocyanates all ran together....
Was it really humid in the booth? did you wet the floor?
When this happens, a "clean" paint job will LOOK dirty.
If that is what happened a wet sand ain't going to make it...
Old Aug 31, 2009 | 01:25 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
i always wet the floor and the filters
Old Sep 1, 2009 | 03:22 AM
tx65coupe's Avatar
tx65coupe
What happened to your trunk that required repainting?
tmdm
May 2, 2021 02:49 PM
04stangman
Sep 17, 2015 01:45 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
cbird1177711
Sep 3, 2015 08:43 PM
SYNY5TER
Sep 2, 2015 01:35 AM
