Squeals when quickly revved
Old Aug 30, 2009 | 11:24 AM
Gun Jam's Avatar
Gun Jam
Yeah sounds like you have a new project for today BA
-Gun
Old Aug 30, 2009 | 11:25 AM
2+2GT's Avatar
2+2GT
Originally Posted by BA Mustang
It is normal.
My 67 does it sometimes. You have to tighten the belt good, but that won't stop it.
Hmmm… Neither my Mustang or Corvette suffer from belt squeal.
Old Aug 30, 2009 | 12:03 PM
JMD's Avatar
JMD
Originally Posted by kalli
a tight belt will stop it unless
- the belt is crap or simply the wrong one
- you are at the end of adjustment, can't get the belt tight
- the pulleys are not aligned
Kalli
There is one more thing...
- The pulley(s) are worn out
I have owned a truck where the "V"s on crank pulley were worn down enough that the belt was resting in the bottom of the groove and NOT on the shoulders of the pulley... It did not matter HOW TIGHT a person got those belts, it WOULD squeal whenever the fan clutch kicked in...
Probably would not happen in a car, but maybe. For me, the solution was to put slightly wider belts in place. (vs. several hundered $$ for a new pulley) This worked fine so long as I made sure people did not replace the belts with the "RIGHT" ones... and this is actually harder than it sounds on a fleet truck....
Old Aug 30, 2009 | 01:06 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
When you quickly rev the motor it shifts slightly. Are you sure you're not squeezing a small farm animal against the right shock tower?
Fan belt or animal? You make the call.
Old Aug 30, 2009 | 01:08 PM
Gun Jam's Avatar
Gun Jam
That's BA's fan belt for sure...no contest.
-Gun
Old Aug 30, 2009 | 01:14 PM
Canary94GT's Avatar
Canary94GT
Hmm it is very possible, will check and confirm engine not squeezing small farm animal against the right shock tower.
Old Aug 30, 2009 | 01:49 PM
kalli's Avatar
kalli
JMD, very true. i've seen a lot of worn pulleys. none ever so far down that the belt would sit on edge. but i wouldn't bee too much surprised to come across one in a very high mileage car. and i hear your: "try to make sure everyone's having to put on the wrong belt". it simply doesn't work :-)
Old Aug 30, 2009 | 02:01 PM
hiboostwoody's Avatar
hiboostwoody
I've also seen one that the alternator pulley was so glazed from years of use that the belt just couldn't grip it but I consider that a freak deal.
Old Aug 30, 2009 | 02:22 PM
1slow67's Avatar
1slow67
ROTM Moderator
-Gun
Can't fix it. I've had the problem since last december. New belt, new harmonic balancer, new water pump, new alternator(with old pulley).
Old Aug 30, 2009 | 02:40 PM
Starfury's Avatar
Starfury
BA, you've got a problem somewhere. It's fixable. What kind of belt are you running? And how tight are you tightening it?
