Squeals when quickly revved
Old Aug 30, 2009 | 02:42 PM
  #21
1slow67's Avatar
1slow67
ROTM Moderator
Not sure what belt. My dad tightened it so I don't know. All I know is he used a breaker bar to pull the alternator away from the block.
It usually only happens when your first crank it up and gun it and also when water gets on a pulley or on the belt.
Old Aug 30, 2009 | 03:04 PM
  #22
65rangoon's Avatar
65rangoon
... i have never seen nor heard of a pulley being so worn that the belt is not sitting in it right.
you guys do realize that a V belt isnt a V belt and that there are different series V belts and they vary in width right?
the belt should be flush or JUST slightly above the diameter of the pulley. if the belt is sitting down inside the pulley, its the wrong belt. length may be right but thats it.
Old Aug 30, 2009 | 03:16 PM
  #23
rmodel65's Avatar
rmodel65
Yukon Cornelius
good lord i never use a pry bar to tighten a belt
Old Aug 30, 2009 | 03:24 PM
  #24
Starfury's Avatar
Starfury
I do. Granted, I'm running two belts on my alternator/wp/crank.
Old Aug 30, 2009 | 03:44 PM
  #25
1slow67's Avatar
1slow67
ROTM Moderator
I know about the different widths, but this was the one I had on the car since I bought it. Now it has 1 that is the same width but about 2 inches longer.
Old Aug 30, 2009 | 04:33 PM
  #26
kalli's Avatar
kalli
if that thing is not adjustable how else would you get it tight without a prybar? it's the easiest way. anything else is just hassle
Old Aug 30, 2009 | 05:29 PM
  #27
4reboy's Avatar
4reboy
My squeals now too (when revved quickly), but only because I've removed my power steering so I only have 1 V-belt for the alternator. It was fine before I removed my power steering so I think I just need to tighten the belt some more... I'll probably do that today.
and my dad has always used a broom stick to tighten the belts. He would pull the alternator or p/s pump tight and I'd tighten down the bolts
Old Aug 30, 2009 | 11:39 PM
  #28
JMD's Avatar
JMD
All three of you guys might try using a belt a mm or two wider....
A "V" beld should ONLY ride on its shoulders, not the inside radius.
Cheap and easy enough to give it a try...
Worked flawlessly on the truck I did this on..
It only had about 300,000 miles on it when the belts started slipping.
Old Aug 31, 2009 | 12:02 AM
  #29
4reboy's Avatar
4reboy
I just might do that, i'll maybe replace my belt with the one that drove my power steering, it looked to be in better shape. I'll also see if the belts fill the whole pulley or not...
Old Aug 31, 2009 | 12:40 AM
  #30
Canary94GT's Avatar
Canary94GT
I can see on my pulleys that the belt is not bottoming out because there is some brown surface rust/patina in the bottom groove but where the belt runs it is smooth.
svfetter
Oct 5, 2015 11:39 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 25, 2015 06:30 PM
ccdguy
Sep 19, 2015 05:20 PM
