18MPG woheeee
Old Sep 8, 2009 | 12:56 PM
69mach1377's Avatar
69mach1377
You show-offs with your fancy mancy air/fuel gages and all...I'm not jealous at all.
Old Sep 8, 2009 | 04:12 PM
kalli's Avatar
kalli
Originally Posted by Gun Jam
if the jet size you are going with is .002 smaller than what you have now you would be looking at .5 to .75 drop in reading im guessing so you would be looking at A/F 13.6 to 14.6 ish....That's about what im pulling at freeway speed.
-Gun
bigger, not smaller ;-) but yes, 14:1 is what I'll be aiming for. but before I do that I'll have to doublecheck the accellerator pump once more. i might just get rid of that hesitation with bigger pump cam. as well I want to try to see if I have the secondary butterfly. i believe if I open that one a bit more I can close the primaries a bit more which should help as well. neverending fun. but i'm still learning
That's what I have the A/F meter for. i'd never get it right otherwise :-)
Old Sep 8, 2009 | 04:23 PM
Gun Jam's Avatar
Gun Jam
Right...jets....I was thinking needle size.
Why are you replacing jets and not needles?
Is it lean under power too? I thought you had the power end running well.
Just get a needle with a .002 smaller cruise diameter and you wont mess up the power side of the equation but still get a bit richer part throttle reading.
-Gun
Scottyboy187
SVT Forums
Nov 20, 2015 02:57 PM
Scottyboy187
Nov 5, 2015 04:18 PM
Jas5
Jun 29, 2013 06:10 PM
paulmorgan
Jun 8, 2010 09:10 PM
runsrich
May 1, 2006 05:41 AM
