C4 no reverse
Old Sep 8, 2009 | 09:36 PM
valley firearms's Avatar
valley firearms
this might help.
Old Sep 13, 2009 | 06:19 PM
makaveli200369's Avatar
makaveli200369
Awesome thanks for the pic. So what part am I looking for? I didn't have time to drop it this weekend. I did realize one foolish thing I did! I used some Mercon/Dextron fluid in it. Although I did start with Type F fluid I ran out and added some Mercon/Dextron my newer ford truck uses. I'll be draining it out when I drop the pan to check for the parts. Think the 60/40 mix could of caused that? I hope it didnt burn anything up...hopefully not since I didnt drive it far
Old Sep 13, 2009 | 06:56 PM
cprstreetmachines's Avatar
cprstreetmachines
Good call thumpin'. No, fluid didn't cause it. When you pull out the servo, the pan needs to be off so you can re-install everything. It's not an in and out job with the servo. you dropped it on there is all. I would pull the VB though. Not worth the trouble to avoid it pulling it.
Old Sep 28, 2009 | 09:17 PM
makaveli200369
Been so busy I haven't had a chance do this yet. I'm going to do it this weekend. Will any check ***** fall out when I remove the valve body?
Gene K
Oct 21, 2015 11:37 PM
foxdude
Sep 24, 2015 08:45 PM
maestro1024
Sep 21, 2015 02:40 PM
LivingInThePast
Sep 16, 2015 12:20 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
