Hood rust
Old Sep 12, 2009 | 08:05 PM
64to66's Avatar
64to66
Default Hood rust
I have been stripping my hood and the rust hasn't been to bad except on the the channels underneath the bracing on the bottom side. Has anyone dealt with this? Do I have to remove the skin? Or order a new hood...
Old Sep 12, 2009 | 10:08 PM
2+2GT's Avatar
2+2GT
If the rust is superficial, banging with a plastic hammer and blowing with air pressure should do it, pushing cleaning brushes into the framing will help, too. If the rust is coming off in flakes, or pitting through in tiny holes, the hood is trash. Replace it with the "original tooling" hood.
Old Sep 13, 2009 | 02:53 PM
64to66's Avatar
64to66
it hasn't pitted and isn't coming of in flakes, but if i run my finger in the channel it is definitely rusty. i am thinking of dribbling por 15 in the holes and trying to work it around in there.... if i don't get complete coverage, will it pose a problem? could it eventually eat up through and come out under the new paint?
Old Sep 13, 2009 | 03:46 PM
mdiak47's Avatar
mdiak47
Replace the hold the rusting is overwhelming.
Old Sep 13, 2009 | 11:50 PM
plcdude's Avatar
plcdude
FWIW. I pulled the skin off of the frame on my hood and trunk lid. It was a bit of work but well worth it. Ford did not put primer on the inside of the frame or the hidden portions of the hood skins.
Old Sep 15, 2009 | 09:41 PM
64to66's Avatar
64to66
do you have any pics of the process? any tips?
Old Sep 15, 2009 | 09:58 PM
Adrenolin's Avatar
Adrenolin
Prep it well by removing as much of the rust as you can with long cleaning and wire brushes followed by the pre por-15 prep. I'd recommend spraying the por with spray rods if at all possible for better coverage. Don't use rust converters if using por.
Old Sep 15, 2009 | 11:46 PM
plcdude's Avatar
plcdude
Here are some pics of removing the skin from my hood.
Step 1. Drill out the stop welds
Step 2. Carefully pry up the folded over skin lip all the way around.
Just takes time and patience. Definitely well worth the effort.
Old Sep 15, 2009 | 11:57 PM
Adrenolin's Avatar
Adrenolin
Just how much time did it take you?
Old Sep 16, 2009 | 12:07 AM
plcdude's Avatar
plcdude
I don't think it took more than 3 or 4 hours to get the skin separated from the frame
