Keys
Old Sep 13, 2009 | 08:21 PM
Flash70's Avatar
Flash70
Default Keys
What are my options if I misplaced/potential lost my keys?? New ignition and locks(hood + doors)? Or is it possible to somehow get the exact same key without the original??
stupid question but I am not sure what exactly my options are.
Old Sep 13, 2009 | 08:45 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
I know that a locksmith can make a key from the code if it's available. Dealers have the code for the vin involved, but this only applies to newer cars. You best bet would be to call a GOOD locksmith and see what he can do.
Old Sep 13, 2009 | 08:46 PM
2+2GT's Avatar
2+2GT
If it's the original lockset, typically has the key code number stamped on the door lock cylinders. Read these numbers to a locksmith, and by the time you get there he'll already have the key made. If not, you'll have to take the cylinder to him.
Go through the back seat and use a socket wrench and many extensions to unscrew the latch. Then you'll be able to re-key or replace the lock.
Make sure you get two sets of keys.
Old Sep 13, 2009 | 09:34 PM
Adrenolin's Avatar
Adrenolin
Keys are cheap.. we have 4 to 5 sets for our cars.
Old Sep 13, 2009 | 09:35 PM
Flash70's Avatar
Flash70
Hm I see. Thank you. I know I should have made 2 sets of keys. I always keep my keys in the garage so I know where to find them but this week has been hectic with the car so I misplaced them.
Just quick question. 2+2 do you own a mustang shop or something? Just curious.
Old Sep 13, 2009 | 09:41 PM
JMD's Avatar
JMD
Many locksmiths will be able to make you new keys on the spot WITOUT CODES.... (with one of those handheld key cutting tools)
Also, with old worn locks, a key that fits the hole will often work well enough to "jimmy" the locks.... (for the trunk)
Old Sep 14, 2009 | 12:05 AM
Cusp's Avatar
Cusp
Pull out a lock set and take it to a lock smith. A key can be made from that set. An easy one to get out. Like a door.
lincolnshibuya
Dec 8, 2015 04:37 PM
logan409
Sep 26, 2015 07:43 PM
jessicarabbit
Sep 25, 2015 12:41 PM
Beerman309
Sep 19, 2015 01:16 AM
Sep 8, 2015 11:50 AM
