ford 9" rear end
Old Sep 21, 2009 | 12:48 PM
2+2GT's Avatar
2+2GT
Originally Posted by Starfury
You found a 9" axle housing that has the proper width for your '66? Or you found a 9" center section? In case you're not aware, you can't bolt a 9" center into an 8" housing.
To answer your second question, the axles are splined to the differential. If you get a 31-spline trac-loc unit, you need 31 spline axles, or a 28 spline trac-loc unit.
Oddly, apart from the housing…
Let's put it this way. If you have a 66 8", and you want to move up, get a 9" diff and 9" housing. The brake assemblies, and even the 28 spline axles will slide right onto the new 9" setup.
OCHOHILL- You found a 9" housing the correct length for a 66? The only one that was actually correct was the one used on 64-66 K code 289HP Mustangs. A very rare bird. You could just get a Currie 8" Traction-Loc, if their figures are accurate it's stronger than a lot of stock 9" rears. That'd save you a lot of trouble. You can get all sorts of 8" gears, too.
One thing you could do right now is install Traction Master bars (not the cheap repros, either) cost a little over $100, and give dramatic results. Then, if you change the axle later, you'll already have them.
Old Sep 21, 2009 | 06:19 PM
OCHOHILL's Avatar
OCHOHILL
I found a 9" the correct width for a 66. The guy I bought it from was a shoe box nova guy. Appearently, chevy guys can take this rear end and it bolts right up to many GM cars. Correct width, spring perch location-everything. The tag on the rear end was not for a 65-6 mustang, but the housing jives.
I did not know the 8" stuff will bolt up. I had to buy a moser axle for the old 8" rear end. Is the moser axle stronger than a stock 9"? Should I swap it for the stock 9" axle?
Both housings are 28 spline small bearing end, btw.
I am currently looking for a used center section with a traction device and taller gears.
Old Sep 22, 2009 | 09:04 AM
Gregg Haughton's Avatar
Gregg Haughton
Default 9 Inch 31 Detroit Locker
I have a 9 inch, 31 Spline Detroit Locker in my car and want to replace it with a clutch posi. It works fine, but I drive around town (don't drag) and it's overkill. I will sell it for $400 or swap with a 9 inch posi.
Old Sep 22, 2009 | 09:07 AM
Gregg Haughton
Default 9 inch detroit locker
Ooops, for got to mention 3.89 gears in the det locker.
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
inyadreems
Aug 21, 2015 09:10 AM
91StangOwner
Aug 20, 2015 11:34 PM
Black_GT_02
Aug 20, 2015 01:26 PM
