1965 coupe window jamb patch panels
Old Sep 20, 2009 | 07:27 PM
bessemerengine's Avatar
bessemerengine
Default 1965 coupe window jamb patch panels
We are beginning a home restoration of a 1965 coupe that had a vinyl top. It has rust holes approx. 2"x1" on the top of the front and rear window jambs near or at the corners. Has anyone been able to find for purchase any patch panels for this area of the car? I am a decent fabricator but would rather purchase the parts if I can since I am working out of a two car suburban garage.
Old Sep 20, 2009 | 07:58 PM
2+2GT's Avatar
2+2GT
The only such section that's practical is the panel between the rear glass and deck lid. The rest is either not available or part of other assemblies so costly it would be a bad idea. Of course, you could cut up that rear piece to make small sections easily.
Old Sep 20, 2009 | 08:25 PM
bessemerengine
I will have to go out and compare the angles but I don't think they would be the same. The flat lip that the window sits on is okay, it is the part that wraps into the roof line that is rusted through. Odd that they make parts for every other part of the car but this. I am use to making repair parts from aluminum or titanium for aircraft, not so much auto body parts. I need to find out what the correct type of sheet metal would be.
Old Sep 20, 2009 | 09:19 PM
2+2GT's Avatar
2+2GT
Mild carbon steel. Way easier to work with that what you are used to. Even I can buttweld this stuff.
Old Sep 22, 2009 | 05:57 AM
bessemerengine
Default This is some of what I am dealing with
Old Sep 22, 2009 | 05:58 AM
bessemerengine
This is my first attempt at including a picture....
Old Sep 22, 2009 | 06:17 PM
groho's Avatar
groho
Take a picture of the sections you need and locate a good wrecking yard. We got one or two out here on the left coast. Just have the sections cut from a wreck. Most wrecking yards have webpages and emails. You can probably do it over the phone. Limit your size/weight for shipping but being specific on the cuts.
Old Sep 22, 2009 | 09:27 PM
2+2GT's Avatar
2+2GT
Must be nice. In the northeast, any Mustang that was not already rotten in those corners is probably being restored.
Old Sep 22, 2009 | 10:38 PM
groho's Avatar
groho
try A&M autodismantlers in Sacramento. Specializes in mustang and falcons. He ships anywhere. Toll Free: (800) 700-4426
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
b8checker
Oct 8, 2015 12:55 PM
UrS4
Oct 3, 2015 06:23 AM
jrrhd73must
Oct 2, 2015 09:17 PM
