windshield replacement
Old Sep 30, 2009 | 09:29 PM
JHPSTANG's Avatar
JHPSTANG
Default windshield replacement
So, the cracks get bigger every time I drive it, so it's time to get the new windshield. Can I do this? It looks pretty do-able, but as always advice is the most valuable gift. If I do it myself I could save a hundred bucks or so, (and maybe get the dash pad moulding in). I've heard about the rope trick, but Mustang Monthly has an article that suggests using a tool to pop the gasket around on the outside. That seems like it could work. Has anyone done one?
Old Sep 30, 2009 | 09:36 PM
Gun Jam's Avatar
Gun Jam
I did...It was easy...
Just pop the trim off using the trim removal tool...Cut the rubber so you can see the edge of the glass then kick out the window.
Clean the channel really well and repair any rust holes.
You'll need to apply 3m bedding compound
I ran a bead of the 3m then used the rope to set the glass which worked really well
Then filled the remaining space between the rubber and the frame with the 3m
refitted window trim
totally give it a shot...you can do it!
-Gun
Old Oct 1, 2009 | 06:08 AM
tx65coupe's Avatar
tx65coupe
I agree, it is very doable. You will probably want an extra pair of hands though.
Old Oct 1, 2009 | 07:21 AM
JHPSTANG's Avatar
JHPSTANG
My confidence is growing.
Is there anything tricky or different because mine's a convertible?
Where can I get a trim removal tool?
Thanks!
Old Oct 1, 2009 | 07:47 AM
tx65coupe's Avatar
tx65coupe
I don't know if there is anything that will make it more difficult on a vert or not. Maybe someone with will chime in.
Old Oct 1, 2009 | 02:53 PM
JHPSTANG's Avatar
JHPSTANG
I just realized the article I looked at online was actually a 67 vert, and made it look pretty simple. I am a bit worried about damaging the stainless trim, but a trim tool and some new clips should prevent too much damage.
Any ideas on where to get the clips?
Old Oct 1, 2009 | 02:57 PM
Piraya33's Avatar
Piraya33
I am pretty sure NPD sells them.
Old Oct 1, 2009 | 05:50 PM
2+2GT's Avatar
2+2GT
Glazier Nolan sells the trim tool I prefer. They have the clips, seals, and bedding compound, too. You'll need two tubes.
Old Oct 2, 2009 | 02:54 AM
mdiak47's Avatar
mdiak47
NPD sells them
Old Oct 2, 2009 | 08:45 AM
JHPSTANG's Avatar
JHPSTANG
Got it. Thanks!
