Disc Brake Help
Old Oct 7, 2009 | 11:50 PM
greasypete's Avatar
greasypete
Question Disc Brake Help
Hi new member here in need of some help/pointers
so i bought a 77 versailles spindle to convert my drums to disc and i have read that there are some issues when using versailles spindles to do this conversion i was wondering if anyone has used this model to convert their mustang to discs and what advice they would have and what i should watch out for what else i need etc..
Old Oct 8, 2009 | 05:34 AM
2+2GT's Avatar
2+2GT
You'll need a pair of 77 Versailles/Granada outer tie rod ends. If you have power steering you'll have to get a special "65-66 power steering with Granada spindle" outer left tie rod end. Cha-ching.
You may also have problems with your wheels. Most factory wheels of the 60's had center holes too small to fit the hub of the Versailles/Granada brake rotor.
Personally I've always thought changing the spindles was too much like work. The 66 factory disc brakes used the same spindle as drums, and since they are available that way, I just use them.
Old Oct 8, 2009 | 12:39 PM
tx65coupe's Avatar
tx65coupe
I have Granada brakes on mine. I had no issues other than the fact the like 2+2 said, the center hole in some of the older wheels wont clearr the hub.
I doubt the braking ability of the Granada stuff is less than the factory 65-66 discs. I don't see how thats possible.
Mine stops great with the Granada stuff. I'm sure there are better setups, but I don't want to be forced to run larger wheels. I want to keep 15 inch wheels on my car.
I also read that there are problems with the Versailles front spindles. I'm not sure why Ford didn't just use the Granada parts on the Versailles. That would have made things easier.
Old Oct 8, 2009 | 07:18 PM
greasypete's Avatar
greasypete
anything else you guys can think of? i heard something about having to buy a shim of some sort or something like an adapter because the Versailles disc brakes use a larger diameter lower ball joint stud? anyone know where i can purchase that?
Old Oct 8, 2009 | 09:55 PM
chris66dad's Avatar
chris66dad
Here is the bushing you are looking for:
http://www.mustangsteve.com/tierodbushings.html
Here is the install instructions from CSRP which is basically the same as what you are doing. Step by step write up is excellent. It will download the PDF file that you can open or save:
http://www.discbrakeswap.com/instruc...3-granada-swap
Might want to look at CSRP kit for $524. It is a great value and deal with quality NEW parts
Here is more info on the kits:
The owner is named Dennis and is a cool guy who will help you with questions and what you need
Old Oct 8, 2009 | 10:18 PM
2+2GT's Avatar
2+2GT
You sure you don't wanna just keep the spindles you have on the car? The factory brakes are quite powerful, and will fit stock 14" wheels.
Old Oct 9, 2009 | 12:21 AM
tx65coupe's Avatar
tx65coupe
I wasn't aware that you could get a kit with the 65-66 discs. That would be cool.
I got those tie rod adapters that chris66dad mentioned for my Granada stuff.
Old Oct 9, 2009 | 01:34 PM
degins's Avatar
degins
I would not bother with shimming the Versailles spindles. The shims are expensive and the steering geometry of the spindles is not OE correct for a 65-66. The Versailles spindles are in demand by mid 50's Ford owners wanting to do a disc brake conversion. These cars need the larger ball joint hole that is on the Versailles spindles. This makes them somewhat valuable and you could sell them on eBay, and then perhaps get a complete kit with new parts.
If your 66 is 5 lug, you could install the 4 piston caliper based OE type disc brakes. If the car is a 4 lug type, you can get a 4 lug, OE correct steering geometry, Granada based kit. Both kits are available for $525-$575.
Old Oct 9, 2009 | 02:32 PM
2+2GT's Avatar
2+2GT
This is the 65-67 factory disc brake.
This is the same brakes in a ready-to-install kit. Note the 67 dual reservoir cylinder, a nice safety touch in an otherwise stock installation.
lincolnshibuya
Oct 6, 2015 08:45 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
