Sway Bar?
Old Oct 8, 2009 | 10:06 AM
Piraya33's Avatar
Piraya33
Default Sway Bar?
Is there a way to tell what size sway bar I have? It was installed on the car when I bought it and I need to replace the bushings but I need to know what size it is. Also, if it's not a 1" then I might get a new one that is 1". Anyone know of any good brands? Thanks!
Old Oct 8, 2009 | 10:59 AM
2+2GT's Avatar
2+2GT
Well, a vernier caliper is the most precise way, but a ruler will do.
Addco has been making sway bars for decades, good value. You should be able to get a 1" bar for about $120. You can spend 2 or 3 times that much, but you don't need to.
Old Oct 8, 2009 | 11:18 AM
kalli's Avatar
kalli
if you have no vernier caliper get on of those tapes that tailors use (mummy will have one). Measure circuference and divide by PI. That'll give you diameter. more accurate then guessing
Old Oct 8, 2009 | 11:25 AM
pass1over's Avatar
pass1over
measure how thick it is, thats what swaybar you have.
upgrading to a larger one is usually always beneficial (especially if its the stocker), unless your drag racing
Old Oct 8, 2009 | 11:33 AM
sixt5's Avatar
sixt5
or take a flexible tape measure, like for clothing or something, and measure around the tube, divide in half to get the radius.
Old Oct 8, 2009 | 11:38 AM
67t5ponycoupe's Avatar
67t5ponycoupe
What? Half the circumference will not give him the radius and he doesn't need the radious anyway he need the diameter.
Old Oct 8, 2009 | 11:40 AM
Piraya33's Avatar
Piraya33
Thanks for all the quick replies. I forgot I had a caliper in my toolbox. I measured it and it is a 1" so I am going to keep it on there. I am going to get some new end links and bushings today. Is it better to use polyurethane on these? I am going to NPD because it is 10 minutes away from me so what should I get? How are the Prothane ones? Thanks!
Old Oct 8, 2009 | 11:41 AM
67t5ponycoupe
Kalli he will need to take the circumference, divide by PI then divide by 2. The formula is 2 PI R= circumference.
Old Oct 8, 2009 | 12:01 PM
Starfury's Avatar
Starfury
I'd use poly bushings on those, Piraya. You want them to have very little deflection.
Old Oct 8, 2009 | 12:15 PM
Piraya33's Avatar
Piraya33
Thanks, do you know how the Prothane ones are? NPD carries them, so I might get those.
