Sway Bar?
Old Oct 8, 2009 | 12:18 PM
Starfury's Avatar
Starfury
*shrug* I imagine they're just fine. Prothane is just a brand. IMO, a sway bar bushings is pretty much a sway bar bushing. As long as it's poly and you grease the frame bushings before install, you should be just fine.
Old Oct 8, 2009 | 12:22 PM
Piraya33's Avatar
Piraya33
What do you mean by "grease the frame bushings"? Any special type of grease? Sorry for all the questions. Thanks!
Old Oct 8, 2009 | 12:30 PM
2+2GT's Avatar
2+2GT
Ford silicone grease D7AZ-19A331-A or something similar. Of course, it's even better if you wrap the bar with teflon tape and slide the bushing over it.
Old Oct 8, 2009 | 12:33 PM
MetalEd's Avatar
MetalEd
It's not as accurate as calipers (I use), but in a jiffy you can take an open end set of wrenches, slide them over the bar. The smallest size of wrench that fits over the bar is the size you have (not precisely accurate for small fractional differences)
Old Oct 8, 2009 | 01:34 PM
kalli's Avatar
kalli
Originally Posted by sixt5
or take a flexible tape measure, like for clothing or something, and measure around the tube, divide in half to get the radius.
check my post above circumference=pi*d (not 2*r), you're maths are a bit rusty ;-)
Old Oct 8, 2009 | 02:27 PM
MetalEd's Avatar
MetalEd
I had the "red" prothane ones from NPD, returned them because they didn't have my size. BUT the ones from NPD come with a little tube of special grease for them specifically. So no need to worry about looking for it.
Old Oct 8, 2009 | 02:36 PM
Piraya33's Avatar
Piraya33
Thanks Ed. I'm heading to school now, so I will pick them up when I get out of class.
Old Oct 11, 2009 | 04:17 PM
KMatch's Avatar
KMatch
Calipers? Pi? ?? Grab a couple of wrenches - 3/4, 7/8, 15/16, and 1 inch. The smallest wrench you can slip the open end over the bar and that's the size it is. Why else did they stamp those numbers on wrenches if they weren't meant for measuring stuff? Even a crescent wrench will work but you still need a ruler to verify it.
Old Oct 11, 2009 | 06:52 PM
Carlos Pineiro's Avatar
Carlos Pineiro
Sway bar bushings are notorious for squeaking. Poly bushings are not as flexible as the natural rubber ones originally installed in cars in the 60s (but they last longer).
CP
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Oct 3, 2015 06:23 AM
fastbackford351
Oct 1, 2015 12:24 PM
winner99
Oct 1, 2015 10:52 AM
Sep 16, 2015 07:53 PM
