64 windshield wiper arm removal?
Old Oct 19, 2009 | 11:06 AM
MetalEd's Avatar
MetalEd
Default 64 windshield wiper arm removal?
Mine is a 64 (may have been upgraded to later) and it looks like there is a little tab between the arm and the window, but I cannot get it to come of. Do I push, pull or pry this tab to get the windshield wiper arms to come off? Any trick to it?
Not replacing them, (cowl work) so I can't look at replacements to see how the mechanism to remove them works.
Thanks.
Old Oct 19, 2009 | 11:12 AM
2+2GT's Avatar
2+2GT
No, just lift under the edge of the fitting opposite the arm. There's a special tool for this, but as long as you avoid scratching the cowl, you'll be OK.
Old Oct 19, 2009 | 12:27 PM
boogerschnot's Avatar
boogerschnot
I used a screwdriver to push up the tab and then wiggle the arm up off of the gear stud.
Old Oct 19, 2009 | 03:49 PM
MetalEd's Avatar
MetalEd
Large screwdriver at the locking tab under the arm and a larger one behind the arm (under the fitting). Twist both and it came right off! Thank you!
I thought perhaps it was like a "C" clip and might need to be pulled up or something. If only I could have seen under it from the beginning, nothing could be easier.
Again, Thanks!
Old Oct 19, 2009 | 07:27 PM
oldrock's Avatar
oldrock
I'll just say they may be stuck pretty good. I had the same issue and ended up chipping teh paint on my mustang. If I ever have to do it again, I will be taping the area and using padding just to be safe.
Old Oct 19, 2009 | 10:45 PM
MetalEd's Avatar
MetalEd
The first one I did not expect the way it sprung off. Since I was using 2 screwdrivers, no hands free. I just tossed a towel folded up a few times over and under it. The weight kept it from springing off.
Old Jun 17, 2011 | 10:55 PM
DavidSoto's Avatar
DavidSoto
Just a share...
I found this very useful writeup for anyone here who will be removing their windshield wiper arm... Hope this helps!
Windshield Wiper Arm Write-Up : http://www.moddedmustangs.com/forums...-write-up.html
Old Jun 18, 2011 | 06:04 AM
tx65coupe's Avatar
tx65coupe
Lay a towel around the wiper shafts to protect the paint.
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
UrS4
Oct 3, 2015 06:23 AM
jrrhd73must
Oct 2, 2015 09:17 PM
UrS4
Sep 30, 2015 10:13 AM
