help with the differences in 9inch rears
Old Oct 20, 2009 | 08:48 AM
built67's Avatar
built67
Default help with the differences in 9inch rears
i have a 67 mustang coupe and i have been looking for a 9inch for a while now. i am going to call some junkyards on Friday to look and see if they have any from a Lincoln Versailles...what year Versailles has a 9inch that will fit into a 67 mustang?...what should the measurements be and where should i measure from...also are those rears nodular iron (i think that's the term)...i read that the stronger 9inches have a "N" on the casing...any and all info is appreciated greatly...thanks guys.
Old Oct 20, 2009 | 09:15 AM
capri man's Avatar
capri man
you do not need the nodular (sp) case. a regular 9 in. case will handle more power than you will probably have. good luck
Old Oct 20, 2009 | 12:04 PM
OCHOHILL's Avatar
OCHOHILL
look here
http://www.kevinstang.com/Ninecase.htm
and here
http://www.nzmustang.com/TechData/9inchdiffs.htm
Old Oct 20, 2009 | 02:07 PM
Silverblade's Avatar
Silverblade
dont have the link here at work but any year versailles i believe will work (75-80), keep the parking brake cables intact
Old Oct 21, 2009 | 02:00 AM
tx65coupe's Avatar
tx65coupe
Yeah all the Versailles rear ends are the same. I think it was 75-80 as well. Definitely keep all the parking brake stuff. An incomplete Versailles rear end is not worth much. Make sure the parking brake levers are on the calipers and dust shields etc are there.
Old Oct 21, 2009 | 07:03 PM
built67's Avatar
built67
i found one on craigslist...just says its a 9inch that fits most mustang rebuilt 3.73 posi 31 spline. asking 400 and its 58" backing plate to backing plate...what do u guys think?
Old Oct 21, 2009 | 10:09 PM
OCHOHILL's Avatar
OCHOHILL
The price is fair if it is complete. Keep in mind you may need to rebuild or exchange the calipers. Also, double check the bolt pattern for the wheel to make sure it matches the bolt pattern you plan on using.
Old Oct 22, 2009 | 03:49 AM
tx65coupe's Avatar
tx65coupe
That is a good price for a rear end that is rebuilt with a good gear ratio and limited slip.
That rear end should work.
This may help you.
http://www.woodyg.com/fairlane/finfo/fordrears.html
musnicki
Sep 23, 2015 07:11 AM
2007CalSpec
Sep 9, 2015 05:37 PM
Dragonus18
Sep 9, 2015 01:21 AM
Doogie65
Sep 6, 2015 02:55 PM
cbird1177711
Sep 2, 2015 08:51 PM
