170 ponys
Old Oct 30, 2009 | 07:29 PM
64.5stanger's Avatar
64.5stanger
Default 170 ponys
can any power be made from 170 ci, still tryin to decide to go through w/the v8 swap?
Old Nov 1, 2009 | 04:17 PM
tx65coupe's Avatar
tx65coupe
I did a V8 conversion on my 65. It is a bit of work, but was rewarding. I would do it again. My car originally had the 200.
If you want to keep it an I6, why not find a 250 or 300 and do a build off of it? The 300 is a great motor, but it might be too tall. I know that quite a few people upgrade to the 250.
Old Nov 1, 2009 | 04:52 PM
2+2GT's Avatar
2+2GT
Yes, the 170/200 can be upgraded easily, 25% increase would be easy.
Old Nov 2, 2009 | 12:39 AM
64.5stanger
read on classicinlines.com/dynoroom.asp 250 can get any where from 211-425rwhp (425=turbo, could the trans n rearend in my car handle that or would i still have to swap out or rebuild/beef up, think id be happy close to 3hundo.
Old Nov 2, 2009 | 12:45 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
when you increase power you start breaking things a 8 inch would be a good idea as would a more beefy tranny
Old Nov 2, 2009 | 02:22 AM
tx65coupe's Avatar
tx65coupe
The 8 inch upgrade would be good as well as front disc brakes like Granada brakes or discbrakeswap.com.
If I was going to build an inline 6, I would not use the 170. From what I understand the 200 is a much better design. I think it has more main bearings. I have heard that from several Falcon guys. I would use the 250.
Old Nov 2, 2009 | 09:57 AM
64.5stanger
would like to do shelby drop,coil drop,@least front discs and proly uca lca. so either way Ill be rebuilding and replacing most of the same things. Getting waaay ahead of my self,as i still need to track down a title, disassemble, do all the metal work, Oh yeah get off this unemployment S! Whoda thunkit nobodys buyn speedboats. getting excited to rebuild a peace of dearborn muscle! proly got awhile before I have to choose a powerplant.
Old Nov 2, 2009 | 10:18 AM
2+2GT's Avatar
2+2GT
Yeah, I was living in south FL when they slapped a millionaire tax on boats and planes in the 80's. Suddenly the powerboat industry was laying off a big piece of the workforce. Duh.
You can do disc brakes on your 4-bolt front end without any other modification, you can even keep the little stock wheels if you want.
The engine upgrades you should do are 3-4 exhaust splitter, dual headers with dual exhaust (stock 2" GT is perfect for this) and a 289HP style air cleaner.
The "Shelby/Arning" drop is a minimum, and a 1" front sway bar. Find a 4-turn steering gearbox. If your car was factory PS it already has this.
IF you upgrade the engine use a 66-up 200, to get the dual bell pattern. This will enable you to use your original trans, and possibly upgrade to a T5 5-speed manual at some point, if you wish. This is an excellent choice of trans for your car. The 250 uses the V8 bell pattern, which complicates your life.
Your 7" will take the 200, even if you upgrade the cam and carb, but if you really get crazy later, and use a performance head, etc., the rear will get a bit iffy.
baddog671
Jul 26, 2016 01:20 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Steve@CJPP
CJ Pony Parts
Sep 24, 2015 02:51 PM
GTJIM
Sep 23, 2015 09:59 AM
