dies when put into gear!
Old Nov 2, 2009 | 09:23 PM
colt1567's Avatar
colt1567
Exclamation dies when put into gear!
hi, i have a 1969 mustang 302ci mustang with an automatic transmission. it dies when i put it into gear. what should i do/ what could be the problem?
Old Nov 2, 2009 | 09:30 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
what is your idle speed? might need to turn it up slightly
Old Nov 2, 2009 | 09:34 PM
colt1567's Avatar
colt1567
Question stalls
i just replaced the anti stall dashpot do i need to adjust it more?
Old Nov 2, 2009 | 11:21 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Can't see where that dash pid would have any affect on it stalling when putting it in gear. I would look at the timing and see if the vacuum advance on the dizzy is good.
Old Nov 3, 2009 | 12:08 AM
BigIron22's Avatar
BigIron22
isn't the anti stall dashpot for when a/c compressor engages. idle speed should be set, at idle in drive so that idle doesn't drop when shifted to drive.
Old Nov 3, 2009 | 11:02 AM
bodyputtyless's Avatar
bodyputtyless
No, the anti stall dash pot is for when the car comes out of running rpm. It activates as the car comes from a running idel to a stop. It prevents the idle from falling below curb idle. .NOTE, just because you replaced the dash pot does not ensure it's working. You have to make sure you have all the specs set properly. Not, hard, just follow the instructions and you'll be successful. BTW, your trouble sounds like you in fact have a problem with the anti dash.
Old Nov 3, 2009 | 11:36 AM
Gun Jam's Avatar
Gun Jam
What years were those on??? I have never heard of them before...mine doesnt have any of that crap.. And where is it located?
-Gun
Old Nov 3, 2009 | 12:51 PM
67t5ponycoupe
Most of the mustangs I have worked on do not have the anti-stall pod and they run fine without it. I have had a few cars with the same symptoms that had ignition timing issues that is why I think it is a timing thing. I would check the diaphram in the vacuum advance and see if it is good. Also check for vacuum leaks.
Old Nov 3, 2009 | 01:01 PM
MetalEd's Avatar
MetalEd
-Gun
64-65 have them I know... I don't think any on the manual transmissions have them. They don't need them.
The carb shop gave me the right autolite 1100 for the year, but it was without the dashpot.. a manual trans. I got it to keep from stalling, but ran like crap and wanted to die... found the no-dashpot problem. Runs like a dream now with the Automatic transmission carburetor.
Old Nov 3, 2009 | 05:21 PM
colt1567's Avatar
colt1567
Red face hmmmm
sounds interesting. all of it. i will check all of it. any other ideas? thanks
StalkerGT
Sep 25, 2015 02:41 PM
musnicki
Sep 23, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
5.0 kevo
Sep 3, 2015 06:24 PM
